Removing Window Tint
[QUOTE]Originally posted by jayhawker
[B]The best way is to spay a soap/water solution to the window (sparingly) and then stick a black garbage bag on the window, and let it bake in the sun for about 45 minutes.
Originally posted by REVN29K
When I took the tint off of my Camaro, I used a heat gun. It heated up the old glue and the whole sheet of tint came off in one piece. I would definitely recommend a heat gun.
Originally posted by QT_S2K
Will a hair dryer get hot enough for this?
I tried a hairdryer but it did not work nearly as good as the heat gun that I borrowed from a friend. I would definitely try to get an actual heat gun it will save you a lot of time in the long run.
