replace softtop?
Old Sep 21, 2004 | 10:53 AM
1qwks2k's Avatar
Default replace softtop?
i have an 01 and there's a member here who has an 04 softtop for sale and im considering buying it and replacing mine with it( because i facking hate the plastic window and all 04's have a glass window). has anyone ever done this? can someone give me a pricce if u have had it done b4? ps he does have the strikers motorts all hardware...
chris
Old Sep 21, 2004 | 11:03 AM
mbilderback's Avatar
You'd have more luck with info on an 02-03 top than an 04 top. I'm not sure, it /should/ be the same as the 02-03 top, but I can't gurantee. Other than that, you need modifry's elastic straps and you should be set.
Old Sep 21, 2004 | 11:21 AM
1qwks2k's Avatar
yeah i know the 04 top is the same as the 02-03 so that's not a prob at this point i just wanna know what kinda labor and instal amounts im lookin at
Old Sep 21, 2004 | 11:28 AM
To put it in perspective, just the plastic window was around $300 labor alone. I'd imagine $500 or so for labor to install the whole top by a /good/ upholstery shop.
Old Sep 21, 2004 | 11:49 AM
California-S2K's Avatar
You always have the option of doing the replacement yourself.
I did it over Labor Day wkend. Used the PDF document and everything went smooth.
Here's the thread:
https://www.s2ki.com/forums/index.ph...opic=99683&hl=
Link to PDF directions:
http://liquidiq.com/S2000/Glass%20Top%20In...%20Ver%202x.pdf
Old Sep 21, 2004 | 12:47 PM
KLN's Avatar
KLN
Is he selling just the soft-top or the soft-top and frame?
If he is selling the soft-top with the frame, the install is pretty easy. You take apart all the interior plastic panels, unbolt the frame, pull old frame and soft-top out, put in new soft-top and frame, then put the plastic interior panels back on.
If he is just selling the '04 soft-top then the install is a little more time consuming. Just follow the instructions posted above.
Old Sep 24, 2004 | 03:54 PM
Halo's Avatar
Now that I've done an upgrade to an 02-03 top (no frame change) on my 01, I wondered if there isn't a little more work involved if you are swapping the frame+top.
What I mean is all of the rubber window seals sit on adjustable aluminum brackets. When removing these, we score the locations of the screws so that the brackets (and consequently those rubber seals) go back EXACTLY where they were before. Once the new top is installed, it is again water tight. I imagine that if you swapped the frame, you'd have to remove/adjust all of these to make sure you had a water tight seal. Not a big deal, but if you screwed one up you'd find out about it at the next car wash/rainstorm.
Anyway, the top swap isn't that hard to do, but it is very time consuming the first time. If I had to do another one I think I could do it in half the time.
I'm still trying to decide if I should just trash the old top or if there is any market for it (15,000 miles all garaged, but window is a bit hazy... I'd say it's a 5 on a scale from 1-10, 10 being brand new).
silvers2k01
Jun 21, 2007 05:22 AM
MrChoi
Jul 28, 2005 03:36 PM
2quick4u
Mar 13, 2005 08:09 PM
geminigsr
Jan 24, 2005 01:13 PM
alexz
Nov 23, 2004 10:18 AM
