Retrofitting the 04 Headrest speakers for previous model years (pics)
Old Oct 16, 2003 | 04:42 PM
lucid's Avatar
Default Retrofitting the 04 Headrest speakers for previous model years (pics)
Hi all, just wanted to share some info and photos of the new 04 head rest speakers
Basically what the factory accessory box comes with ($499 MSRP) is:
2 speaker mounts
1 interface cable
instructions
template
screws, pads, clips etc...
The speakers are 8 ohms wired in parallel bringing them down to 4. That how you get the stereo from factory decks. In other words, the right passenger and right driver and left passenger, left driver are wired together. 1 plug to the deck yields 4 plugs to the seats. You take off the seat assembly (held by only 4 clips), use the template to drill out 4 screw holes to mount it, screw it in, pull up the seatback and run the wires down. Plugs into the wire cable to the deck.
(view of speaker mount in the stock seat headrest assembly)
Sound itself is very good. Top down you'll hear everything but deep bass tones. The speakers are plastic so they'll stand up better than paper.
(Side view of speakers)
(paper cutout)
(cable to the head unit)
Yes, these will fit all model years.
Using our rear speaker harness (with interface plug to the cable run) you can connect any stock deck
You can wire them to an amp or aftermarket as long as you mind the load
We'll have something up shortly online INCLUDING the rear harness for MY00-03 decks for UNDER $499
Thanks
Old Oct 16, 2003 | 04:53 PM
Waterbug's Avatar
Edit - Guess I posted too quick, thanks for speaker pics. Any idea on the specs of the speakers? They must be damn good speakers for $500.
Old Oct 16, 2003 | 06:21 PM
ruexp67's Avatar
That's a much nicer setup than I thought it would be. Thanks for the info Lucid!
Old Oct 16, 2003 | 07:16 PM
asu_lee's Avatar
So there is no cutting on the seats for the install right?
Old Oct 16, 2003 | 07:38 PM
lucid's Avatar
Waterbug - The speakers CAN be changed out to something else, I'm looking into it. Anything from Honda cost $$.
Asu -- You do have to take apart the seat and drill holes in that headrest piece.
Old Oct 16, 2003 | 07:45 PM
asu_lee's Avatar
I was just worried about leather destruction. Looks like that is not an issue. Are you going to sell the harness to adapt them into a aftermarket deck separately.....Are most aftermarket decks 4 ohm standard output?
Old Oct 16, 2003 | 07:47 PM
asu_lee's Avatar
Marcus,
Can you please post the diagrams from the ESM for the headrest removal?
Old Oct 16, 2003 | 07:54 PM
JRock's Avatar
So are these speakers really worth it? Are they quality enough to be worth getting?
Old Oct 16, 2003 | 07:56 PM
Johnny--2K's Avatar
i would also be interested in this if they can be wired into aftermarket decks easily!
Otherwise, i have Diamond components in the doors with
crossovers, so if i can wire them into that it would work fine too!
Old Oct 16, 2003 | 09:54 PM
wickerbill's Avatar
$500 for some $30 speakers in a neat little enclosure is a little ridiculous.
