Rhino Ramps Or Anything Else?
Hi All,
Has anyone had any luck using Rhino Ramps for your S2000? I'm planning to perform the minor maintenance work myself, but I'm not sure what's the best way to get under the car.
BTW, I also have the chin spoiler.
Any thoughts? Thanks in advance!
I just use the stock jack to get one side of the car high enough to get a floor jack under the center jacking point. Then I raise the car and throw the jack stands on each side. Doesn't take any time to do this.
Not only do I own the Rhino ramps, I have the front chin spoiler, too. It is not a problem. The front will come in contact with the ramps, but just a little, and it won't mess anything up at all. You will have nothing to worry about, that is unless your car is lowered.
Happy wrenching!
Happy wrenching!
Happy wrenching!
Happy wrenching!
I have the Rhino ramps and a the Honda chin spoiler. The ramps are too high to pull straight onto. The spoiler hits the ramps before the tires make contact.
I had to cut a couple of 2x12 boards to pull onto first.
exactly i have a oem front lip with the black rhino ramps with oem springs and it will not clear the ramps. are there any lower ramps out there? my life would be so much easier if i could just fond thr right low profile ramps. I mean you call the rhino ramps low profile? are you serious?
