Road & Track Does it! NSX Vs S2000
Old Feb 25, 2001 | 05:28 PM
y2ks2k's Avatar
http://www.roadandtrack.com/RoadAndTrack/A...brands_pg5.html
Steve Millen again is the main guy here.. This is what he says about the M Roadster and I quote "I don
Old Feb 25, 2001 | 05:47 PM
S2000 Driver's Avatar
Old news which has been discussed extensively here in the past.
This is from the January 2001 issue of Road & Track Magazine where they compare the S2000 to the NSX.
In error, they give the S2000 the 0-60 mph acceleration and 60-0 mph braking stats from the NSX.
Old Feb 25, 2001 | 07:34 PM
StudentDriver's Avatar
I know the S2000 #'s were identical to the NSX, but where did you get the Info that it was a misprint?
Old Feb 25, 2001 | 08:09 PM
Sev's Avatar
Sev
There has been no proof of this.
I believe the 4.9 since it can be a 4.99 is possible for the s2k. I have done a 5.11 and my car wasn't even fully broken in yet.
I don't want to get into this again, but you shouldn't be saying it was a misprint without being sure.
Old Feb 25, 2001 | 08:29 PM
y2ks2k's Avatar
Agreed Sev, they even SAY in the article:
"Many will point out that its
Old Feb 25, 2001 | 08:33 PM
gregstevens's Avatar
Banned
Did R&T make a retraction in the subsequent issue? I don't recall seeing it.
What is your basis for claiming it is a misprint?
Old Feb 25, 2001 | 09:36 PM
ultimate lurker's Avatar
Its most likely a misprint for the following reasons:
4.9 is awfully fast for an S2K
The NSX acceleration and braking stats are identical to the NSX test index stats listed in the back
The S2K accel and braking stats are identical to the NSX stats
The S2K accel and braking stats don't match the S2K stats in the test index.
If you look at all the other cars' stats, they match the test index for that particular car. The S2K is the only one that doesn't. And from people who have driven both cars back to back, the NSX is definitely quicker.
UL
Old Feb 25, 2001 | 09:41 PM
Andre's Avatar
i disagree
Old Feb 26, 2001 | 12:11 AM
SixthGear's Avatar
One reason why there're no concensus for 0-60 time for the S is IMO its high redline and launching possibilities. Just look at the below published numbers, my guess is that R&T got the time by launching around redline. MT did say they launched at 8K RPM.
estimate of launching rpm
R&T = 4.9s 9K +
C&D = 6.8s 4-5K RPM
MT = 5.8s 8K RPM (confirmed)
This also means that if it's launched at 4k rpm, you'll probably get something closer to 8 sec! The NSX' 0-60 time of low 5's is more consistent because where you launch doesn't matter as much. That car, especially the 97 and later models, takes much less effort going fast. The S can put up impressive numbers if you're willing to climb the rpm ladder for it. Personally, I'm more comfortable revving the car on 3rd-5th gear. It's better on the tranny and engine i figure... maybe just psychologically thing.
[Edited by SixthGear on 02-26-2001 at 01:19 AM]
Old Feb 26, 2001 | 12:15 AM
That's o.k., but just check the road test summaries and I think you'll change your mind. The "Battle of the Brands" was done in Jan 2001. I pulled out my September 2000 issue and looked at the road test summary there.
The results(0-60/60-0)
M Roadster 5.4/121 - Sept Issue, tested at 5.4/121
Z8 4.5/122 - Sept Issue Summary 4.5/122
Camaro SS 5.5/129 - Sept Issue Summary 5.5/129
Corvette Z06 4.6/123 - Sept Issue Summary 4.6/123
360 Modena 4.3/110 - Sept Issue Summary 4.3/110
550 Maranello 4.7/112 - Sept Issue Summary 4.7/112
S2000 4.9/134 - Sept Issue, tested at 5.5/123
NSX 4.9/134 - Sept Issue Summary 4.9/134
SLK320 6.7/129 - Sept Issue Summary - no listing
SL500 6.2/125 - Sept Issue Summary - 6.2/125
Boxster S 5.6/125 - Sept Issue, tested at 5.6/125
911 Turbo 4.0/119 - Sept Issue Summary - no listing
Now, aside from 2 new cars which may have been tested in the intervening months, you'll note that the times already listed in Sept are identical to those provided in January. I don't think R&T retested those particular items. Looks like they just went to the roadcourse and ran timed laps. There is simply no way that 9 of those cars would record identical 0-60 and 60-0 measurements 4 months later - R&T doesn't correct for conditions and there is always a margin of error. And the odds that the S2K would record exactly the same numbers as the NSX despite being 3 seconds slower on the roadcourse are about as bad.
So, in conclusion, the S2K numbers are in error, IMHO.
UL
