Roller bearings in soft top frame
Old May 21, 2010 | 10:45 AM
Carbon Blue's Avatar
Default Roller bearings in soft top frame
Hey guys, I have a brand new soft top on my 02s2k and when I make left or right turns it sounds like there is one roller bearing that rolls around in the tube frame thats directly on top of your head (when the top is up of course). Its not noticeable but im being picky. Sometimes it doesnt even make any noises, has anyone else had this problem? If so how did you fix it? Im thinking about drilling a hole into the frame because my OCD is driving me crazy.
Old May 21, 2010 | 10:53 AM
tiger1964's Avatar
I've had that ever since I got my top & frame repaired (usual tensioner/tear issues) and I presume someone drilled out some pop-riverts and there are fragments of the old rivets trapped up there. Not much I can think of for it, although I considered drilling a small hole, injecting some epoxy, and driving around, jerking the car left and right trying the embed the frags in the glue.
Ultimately, I realized I always avoid having the top up anyway...
Old May 21, 2010 | 11:26 AM
thebig33tuna's Avatar
i've got one too. been in there as long as i've had the car i think. rolls allllllll the way down to one side, then back again...
i don't even noticed it anymore. i never thought to even bother trying to do anything about it.
Old May 21, 2010 | 12:35 PM
thomsbrain's Avatar
I've got it, too, ever since having the top replaced. Pisses me off when the top is up (luckily that is very rare).
Old May 21, 2010 | 01:09 PM
pmptx's Avatar
There is a DIY which tells you that there are two openings you can pull a plug on to get the rivet pieces out.
Old May 21, 2010 | 02:10 PM
SheDrivesIt's Avatar
The ends of the tubing should have plastic plugs in them.
Old May 21, 2010 | 03:14 PM
RedY2KS2k's Avatar
For the tubes where you can remove a plug, unplug both ends of the tube; use a rubber-tipped blow gun with an air compressor to blow them out. I'd start with low pressure and gradually increase it so that you use just enough to get the job done.
Old May 21, 2010 | 03:38 PM
worked like a charm! 4 of em rolled out, but that was only after driving in 1st gear and making rounds around my cul de sac, Thanks guys!!
Old May 22, 2010 | 10:42 PM
viper_driver's Avatar
look for the tube that slants down slightly at the ends and has black plastic plugs in it with black tape holding the plugs in. Remove the tape and the plugs. It's easiest to do this with the top half way down. With both plugs out, blow through one side, and the rivet pieces will fall out the other side.
i drove like this for years before I figured this out.
Old May 24, 2010 | 04:34 AM
tiger1964's Avatar
That sounds like more fun than using compressed air...
