Rough Engine Starts and Stops
Old May 9, 2004 | 06:00 AM
SolReborn's Avatar
Default Rough Engine Starts and Stops
When I start or kill my engine, sometimes it feels a little rough. I mean rough as in... I feel the car shake a bit. Is this normal due to the power of our engines? Or is there something possible wrong with my car.
Since I bought my S used, could this just be my paranoia from buying a used car?
Old May 9, 2004 | 07:17 AM
TunedS2000's Avatar
I could be totally wrong but I had a simular problem on my 3000GT VR-4 before I sold it to get a S2000. It turned out to be bad motor mounts which was causing shaking every now and then in my 3000. Remember I am not the smartest one here so I could be wrong.
Old May 9, 2004 | 07:34 AM
RazorV3's Avatar
i know it can be pretty rough when i kill the engine, never really noticed anything significant when starting the engine.
how many miles on your s?
Old May 9, 2004 | 08:24 AM
SolReborn's Avatar
Only 26k... I notice that it is more rough when I kill the motor too. Sometimes when I start, it may not be as rough... but it won't start smoothly and will shake more than I was used to on my last car... a Del Sol
Old May 9, 2004 | 08:53 AM
RazorV3's Avatar
from what i read, it sounds ilke normal operation. this car is not your typical honda, you will hear many noises and feel things that sound bad, but you will soon realize that it's just normal. if it makes you feel any better, try test driving another s2000 in your area and see if you experience the same thing. if you have extended warranty, i'd have honda check it out.
good luck.
Old May 9, 2004 | 09:15 AM
SolReborn's Avatar
I bought my s2k used with 22k miles on it. At first, all the noises scared me... the loose clutch plate... the loud engine, rougher engine starts/kills... but I've had it for 3 months now and am now starting to accept it all as normal behavior for such a high compression engine...
Thanks for the confirmation, though... you have really given me much needed piece of mind!
Old May 9, 2004 | 10:22 AM
44Runner's Avatar
mine is also rough on starts and stops. One thing that will help with the starts is to hold the start button longer. If you just push it quickly only long enough for it to turn over the engine will sputter until it works its way to idle. There is nothing you can do on the stops and would not be surprised if that were normal for an engine with such a high compression ratio because the engine stops quicker once the power is cut...
Old May 9, 2004 | 11:17 AM
SolReborn's Avatar
Great to hear that this is a normal occurance. Once again, thanks guys
FIRSTCAR-S2K
Oct 23, 2015 05:27 PM
Bigeggroll
Feb 16, 2005 08:42 PM
GregC21
Apr 5, 2004 07:13 PM
SJSHARKS
Jan 27, 2003 03:59 PM
