Rough Part Under Black Windshield Tape
i peeled off the black windshield tape off my car recently and notice right above the driver side on the opposite side of the catcher there is a dull spot.. and in the middle it almost look like it is lacking paint.. i run my finger over it and could feel it indenting.
Does anyone know what i should do? how common is this problem? its damn ugly!
I pulled the tape off the day I got it. There were two areas that looked like the paint was not buffed or the clear coat was not applied.
I used an alternating procedure of Dupont heavy-duty rubbing compound (green can-paste) and Scratch-X.
I had to work at it maybe 3-4 times but it came out looking like the rest of the car. Don't be too agreessive with the compound-you could take it down to primer with too much pressure! Just 'sneak up' on the desired finish.
In all fairness, since it was covered in tape I didn't expect the finish to be perfect.
I was lucky, I've heard of some that had to respray the area.
Regards,
BD
Regards,
BD
I want to take mine off something fierce but I don't like surprises..... Especially where it's located it's high VIS and I don't like flaws. I'd probably end up spend an A$$ load of money fixing it when I should be spending the money on something else.
I guess when I feel "lucky" I'll roll the dice and peel mine off.....
The longer you wait, the more the tape becomes 'stuck'.
As it was on a 90 degree day with a car that was about 2 months from its build date, it was a tough job taking all the tape off- it came off in little strips which was a PIA to get off- not to mention the residual adhesive.
BD
BD
BD
BD
BD
BD
