S2000 Areodynamics: Good or Bad?
Old Nov 6, 2002 | 02:57 PM
Optikal's Avatar
Default S2000 Areodynamics: Good or Bad?
Some of the threads I've read in the past mentioned that the S2000 has poor areodynamics in comparison with the 350Z...
Now, is this because of it being convertible? Or is it the general shape of the vehicle that puts it at a disadvantage? (if there is a disadvantage, is there anything to produce better aerodynamics to squeeze out better times?)
Any thoughts or recommended resources to check out? It seems odd that any car company would release a sports vehicle with poor dynamics.
Old Nov 6, 2002 | 03:11 PM
stockae92's Avatar
my guess would be the aerodynamic of S2K is pretty bad cause of the angle of the wind shield. i thought i read about the coefficient before and it's something like 0.37 (0.38)?
with the top down, the aerodynamic will be even worse. (should be true for all convertable (maybe except 360 spyder ))
and have you notice how dirty the tail gets after each drive? it could be the tires are kicking so much dirt up or the air exiting the tail is really wild and bringing all the dirt up ...
Old Nov 6, 2002 | 03:27 PM
DarioManfretti's Avatar
The aerodynamics would probably get better with a hard top.
Old Nov 6, 2002 | 05:20 PM
Elizer's Avatar
REAR AIR DIFFUSERS!
Old Nov 6, 2002 | 05:33 PM
JL9000's Avatar
Most cars do that, it's because the air goes through both the top and bottom, the air on top tend to "curl back" to its original path, and all the brake dusts and dirt get carried back onto the rear bumper. It's hard to explain what that looks like.
A properly designed rear spoiler should change the direction of the air and as a side-effect blow much of the dusts away from the car. There are significantly less dust on my brother's 330Ci now that he installed the M lip spoiler, believe it or not.
I think overall the aerodynamics are acceptable for a convertible car. The stand-up windshield definitely does not help, nor the do the ridges on the soft top. I think the car can use more rear downforce.
I seriously doubt that by lowering the aerodynamic drag will help you accelerate faster on the drag strip. The drag is only felt at high speeds that your car probably won't see on the drag strip. I wouldn't worry about it.
Old Nov 6, 2002 | 05:49 PM
alexchou's Avatar
i think our S have pretty bad aerodynamic, especially when you're driving fast... i mean 100+mph the wind noise is mostly because of the high angle windshield. i think the reason for that is honda wants to mimic the shape of the classic convertible S500 & S600.
compare w/ the 350Z and the new G35 coupe, which have pretty low coefficient drag ( i believe it's around 0.27) even the LS430 has lower coefficient drag than our car!!
Old Nov 6, 2002 | 06:39 PM
MacGyver's Avatar
Originally posted by stockae92 and have you notice how dirty the tail gets after each drive? it could be the tires are kicking so much dirt up or the air exiting the tail is really wild and bringing all the dirt up ... [/B]
To add to JL's explanation...
Plastic bumpers and spinning metal/rubber objects have an interesting little side-effect...they tend to create a lot of static charge. After some serious driving, the rear bumper will tend to have a nice negative charge on it, enough to really get those fine dust particles to stick to it. Most newer cars will have this problem since they have plastic bumpers...
Old Nov 6, 2002 | 08:10 PM
stockae92's Avatar
Originally posted by UFeniZe
REAR AIR DIFFUSERS!
i thought about it and i really like the top secret one
but i have doubt to spend $1k+ for some unproven add-on ...
and how its going to affect the diff. temp?
very little have experience with it (or want to talk about it )
Old Nov 7, 2002 | 02:02 PM
MarkS2K's Avatar
It's definitely the angle of the windshield that makes the aerodynamics bad. Even with a hartop, it's not going to make much difference on the coefficient of drag.
I switch cars back and forth between my S2K and Prelude. The angle of the windshield is so much lower than in the S2K. The S2K windshield is practically straight up, when compared to the one on my Prelude.
Old Nov 7, 2002 | 02:08 PM
I believe the windshield (frame) angle might, also, have something to do with safety in a roll over. If it were slanted more, the frame might collapse.
