S2000 CNC Cylinder Head
Old Jul 25, 2003 | 11:40 AM
  #21
turbo_pwr's Avatar
Ok no offense but that 332hp number is probably wrong. Look at the quote that Fongu posted "even though Baechtel saw this as "a little optimistic," .." I'd bet they are no where near 332hp more like 300hp and remember this is at the crank not at the wheels. As for the speed, let's not forget that the speedo on the cars is wrong so it's very possible to see 150 to 160. The speed they posted was more accurate since they were using different testing gear.
Old Jul 25, 2003 | 12:06 PM
  #22
smccurry's Avatar
[QUOTE]Originally posted by turbo_pwr
[B]Ok no offense but that 332hp number is probably wrong.
Old Jul 25, 2003 | 12:14 PM
  #23
SJSHARKS's Avatar
Good point although they used narrower tires on the Speed run, so that could have offset some of the additional drag(if any)associated with the lake bed.
In any event it sure makes you wonder if the S2000, with 50 less HP than the Bonneville car, could ever approach 150 MPH in stock form.
Old Jul 25, 2003 | 01:50 PM
  #24
cjb80's Avatar
My secret forumla developed by me using simple math indicates that 255rwhp is about 298 flywheel hp.
Old Jul 25, 2003 | 02:25 PM
  #25
twohoos's Avatar
1) The C&D article was whack; there were several errors that indicated the author just got a few technical details confused.
2) Even if you believe the C&D guys got what they claimed on the dyno, it's meaningless because there's HUGE variance from dyno to dyno. (And yes, 332 at the crank is just a ridiculous estimate for 255 at the wheels.)
3) The reason they couldn't manage a great top speed is primarily the altitude at Bonneville, which is something over 4000 ft. This robbed them of a lot of power, and they ran out of running room to get those last few mph.
And last:
4) Still waiting for the before/after dyno plots of the R&D head. (Isn't "Dyno" in their name?)
Old Jul 25, 2003 | 02:31 PM
  #26
SJSHARKS's Avatar
They had THREE MILES to get up to speed.
Old Jul 25, 2003 | 05:57 PM
  #27
honda606's Avatar
I can hit 140-145 on a two to three mile stretch of I-45, but after that the speed just all seems the same and I usually let off the gas. When I do get to the let off point the car doesn't feel like it is getting slower acceleration wise, which would lead me to believe that 150 wouldn't be too hard to attain.
Old Jul 25, 2003 | 08:58 PM
  #28
zboult's Avatar
Originally posted by smccurry
Not only that, but remember also that they are running on a dried up lake bed as opposed to a paved surface. I'm no expert on the subject, but there was a thread on that article when it came out, and there was mention of the fact that additional drag is created by that surface. Also, don't they average the speed for both directions to negate the effects of wind aiding in the final result?
True softer surfaces cause more drag.... and what about the altitude and temp you most take those into perspective likewise
Old Jul 28, 2003 | 07:21 AM
  #29
Gernby's Avatar
Former Sponsor
The higher altitude should result in less aerodynamic drag, so less power would be needed to attain a top speed, right?
Old Jul 28, 2003 | 07:45 AM
  #30
cjb80's Avatar
You guys are thinking too much, just slap a turbo on it and be done with it.
