S2000 CR Brakes?
Old Nov 21, 2007 | 09:09 AM
Amer's Avatar
Default S2000 CR Brakes?
I checked out the Honda website and noticed that the S2000 CR brakes hasn't been upgraded. Is this true? What kind of track car does not have upgraded brakes? Are the rotors, calipers, pads, brake fluid etc. the exact same specs as the AP2?
Old Nov 21, 2007 | 09:11 AM
alejo's Avatar
yes - AP1 and AP2 brakes are both excellent - only difference is the AP2 has a slightly different pad compound.
the OEM are more than enough to stop an S with race compounds. the only negative is that they are rather heavy...
Old Nov 21, 2007 | 09:14 AM
Amer's Avatar
But can the AP2's survive track days without fading/boiling brake fluids?
mxt_77's Avatar
^ Go look in the R&C forums and see how many of those track cars have upgraded calipers/rotors. You'll likely find approximately zero. Other than upgraded pads & fluids, the stock S2000 braking system is sufficient to handle the braking duties on track. However, pads that are used on the track are not generally suitable for daily-driving duty, which is why Honda doesn't put in track pads from the factory. And the OEM pads are actually fairly competent for autocross and light track duty.
Old Nov 21, 2007 | 09:22 AM
alejo's Avatar
absolutely - but only when you add racing fluid and pads. oem will fade indeed - but is not the brake system, just the pad/fluid combination.
if this is what you meant then you're right - they should have put more aggressive stuff. problem is that the aggressive stuff is noisy and dirty.
alejo's Avatar
Old Nov 21, 2007 | 09:24 AM
Ks320's Avatar
[QUOTE=mxt_77,Nov 21 2007, 01:14 PM] ^ Go look in the R&C forums and see how many of those track cars have upgraded calipers/rotors.
mikegarrison's Avatar
The kind that came with good brakes in the first place.
Old Nov 21, 2007 | 01:34 PM
jeggy's Avatar
Originally Posted by Ks320,Nov 21 2007, 10:24 AM
The EBD distributes the brake force pretty well between the front and the back
EBD? Electronic Brake force Distribution?
the S has that?
i always thought it was just ABS and nothing more.
Old Nov 21, 2007 | 01:38 PM
[QUOTE=jeggy,Nov 21 2007, 02:34 PM] EBD? Electronic Brake force Distribution?
