s2000 unstable at high speeds?
Old Feb 8, 2005 | 05:57 PM
thonda's Avatar
Default s2000 unstable at high speeds?
i am finding that i have to constantly correct the steering w/ the s2000 to keep it straight on high speed runs and sometimes even normal highway speeds....do you guys see this also? I do have aftermarket 18" w/ AVS ES100 tires on it.
Thanks
Old Feb 8, 2005 | 06:03 PM
Chaka_01's Avatar
Exatcly what speeds does it become unstable? Does it pull only to 1 direction all the time or does it become squirley
Old Feb 8, 2005 | 06:15 PM
Wisconsin S2k's Avatar
i've never had this problem. i've even had the car up to 120mph with my snow tires on and it's been fine.
Old Feb 8, 2005 | 06:17 PM
S2oooNvegas's Avatar
is the car dropped.... either way, get it aligned. probably have too much negative camber, and too much positive toe. car will be a drifty sucker if this is the case.
good luck. dave
Old Feb 8, 2005 | 06:18 PM
thonda's Avatar
seems to become squirley compared to my other car and some others i've owned. Maybe i just have to get use to it.
Old Feb 8, 2005 | 06:19 PM
Nishant's Avatar
prob just needs alignment..i've had mine at 130+ at road courses and it went straight
Old Feb 8, 2005 | 06:25 PM
xda2000's Avatar
mine had the same squirley feeling, even had it aligned. feels the same
Old Feb 8, 2005 | 07:04 PM
Zeniac's Avatar
I've topped out at 146mph on the speedo and not experienced any problems. Could be alignment, or tire pressure also, it should definitely be checked out and corrected though as it could have disastrous consequences.
Old Feb 8, 2005 | 07:06 PM
RazorV3's Avatar
do you still have the "reverse" mudflaps installed near the front wheelwell? they supposedly help stabilize the car during high speeds.
Old Feb 8, 2005 | 07:09 PM
RACER's Avatar
If you posted your alignment specs, I could give you a pretty good idea of how your car will handle.
