S2000 Weight Limit
Old May 24, 2004 | 07:53 PM
Splyt2nd's Avatar
Default S2000 Weight Limit
Hello everyone, I am new to the forum and really really want to get a question clarified. I feel stupid for believing this comment that I saw on Edmunds.com regarding the S2000 but this guy said...
"Everyone wants to race you. 20+ mpg in the city. read warranty manual closely. only carries 400 pounds including passengers. "
400pounds?!?! If so, wow, I have heard many people with rear bearing failure problems, and I by no means know alot about the S2000 (which is why I came here for info), but would this bearing problem be associated with too much weight on the vehicle?
Just lookin for some incite on this "problem" TYIA
-Justin
Old May 24, 2004 | 08:00 PM
steven975's Avatar
wheel bearings? I doubt it. but maybe, anything is possible.
Old May 24, 2004 | 08:01 PM
shift_9k's Avatar
Yea it says 400 pounds. Never knew what the outcome would be if you ignored that.
Old May 24, 2004 | 08:04 PM
SimbaDogg's Avatar
its just because the tires are not rated to carry anymore than that.
Old May 24, 2004 | 08:05 PM
shift_9k's Avatar
So what? They're gonna pop?
Old May 24, 2004 | 08:22 PM
Smokee's Avatar
Where have you heard about so many bearing failures?
400 pounds is correct. Good reason to lose weight and a good excuse to be choosy about passengers.
Old May 24, 2004 | 08:27 PM
Splyt2nd's Avatar
http://forums.s2ki.com/forums/showthread.p...threadid=192266
just a thread that I found browsing the other night, thought on it and remembered seeing the 400lb "limit". Thought there could be some relation. . .
Old May 25, 2004 | 04:30 AM
2000celicaspeed's Avatar
many many times have i had WAY more then 400 pounds in the car...i myself am 220 and i have had passengers that are about the same and i had stuff in the trunk!
Old May 25, 2004 | 05:16 AM
Luft46's Avatar
My '84 and '91 CRXs had the same 400 lb weight limit.....
Old May 25, 2004 | 05:42 AM
Elistan's Avatar
I think wheel bearing failures have more to do with high cornering forces. It's not related to cargo weight, I think.
I also seriously doubt that carrying over 400lbs will cause any issue - as others have said above, it's done fairly regularly with no problems.
I think Honda puts that in there in case somebody tries to tow their jet ski or whatever to the lake, breaks something and tries to get it fixed under warranty.
