S2k 11kRPM
Originally Posted by koala,Jun 13 2005, 11:51 AM
10,000 to 10,500 has generally been regarded as the absolute maximum for the F20C with some serious work.
You're probably looking at $15,000 USD.
Originally Posted by ott#1,Jun 13 2005, 02:05 PM
Ok,
I see, but you didn't write what i need to change/replace !.
Thank You
OTT#1
Thank You
OTT#1
Well, if you are serious and want a serious answer,
It probably cant be done. If it is in fact possible, it will probably
require components that arnt redily available.
Did you know that the F20c motor at 9K rpm is undergoing TWICE the stress as it is when it is at 8K rpm?
For it to rev to 11K rpm, the piston speeds would be astronomical.
(as if they arnt high enough already at 9 grand)
What you need to replace is:
EVERYTHING. Rods, valves, springs, crank (de-stroke it), everything.
Problem is, I am not sure that the stuff that we can buy will stand 11K rpm. I highly doubt it.
You need to go talk to the Indy or F1 people or something.
Or just get a streetbike.
