safety on the S~
hi,newbie question sorry, but im thinking about getting and S , but i would like to know,the safety on this car can be. Does this car hug the road well? it doesnt seem to have dsc/vdc like some other cars hav. so what i would like to know is if this car spins out easily such as in rain on the highway? cold weather. wat is the crash safety on this car? thank you
car is fairly safe from all the crashes i have seen and if you dont actually drive this car you will end up in a curb or worse it isnt a evo or some other car that basicly is error proof i would write more but its 5 and im tired as heck
whoa.. you know more than a couple of people?? these car lose grip easily or something?? man must've rolled through bad weather im guessing? cause if they only got a scratch or two, their top must of been closed?
http://www.euroncap.com/content/safety_rat...p?id1=8&id2=121
here is some info on euro crash testing
Yes the rear end can lose grip easily in certain conditions, but many accidents in this car could have been prevented by driving to the conditions and appropriate speed limits.
Top being closed has little to do with it.
There is a tendency for the car to balance on the windscreen and the bonnet and therefore keep occupants off the ground.
safety wise, the car is actually probably more safe than most coupes, and has excellent safety ratings, acheiving the maximum ratings in both front, rear, side, and front offset collisions. (you can read about honda's safety testing in daniel f carney's book)
so crash wise, the car is probably more safe than many you encounter on the road, largely in part due to honda's safety engineering.
as for stability, that depends on the driver. even systems with vdc and such do no good with a bad driver. the car is not as forgiving as some if you push it hard, though the 04-05 models are a bit more "idiot proof" so to speak.
The best way to operate the S2000 is to drive way beyond you skill and experience, go too fast into a corner, panic and lift off the gas. The S2000 will detect this situation and activate the Onboard Heuristic Stability/Hydroplane Intervention Technology (OHSHIT) system. You
