Safety tip when refueling (gals especially, please read)
Here's some interesting data from a email I received.
FYI:
This was sent to me and I have been hearing of this problem.
(fumes and vapor are not a good thing!) My sister-in-law (an engineer for GM) sent this to me. I found it interesting and worth passing along.
Ironic. I was just out at the GM Proving Grounds on Tuesday and we saw a presentation on electronic magnetic discharge. We were told that vehicles contain more and more electronics - items like CD players, OnStar, satellite radio,in addition to cruise control, ABS, on-board diagnostics to electronically controlled fuel injection. All of this put together with vehicle materials, such as the Scotch Guard on the seats, creates more
static. That's why you are more likely to get shocked just getting in and out of your car.
At MPG (Milford Proving Grounds), they stressed the two most important points to remember are:
- Don't use cell phones while fueling
- Don't go sit in your car while filling up the tank - especially in
dry (and cold) winter conditions
Subject: Stop Static
Bob Renkes of Petroleum Equipment Institute is working on a campaign to try and make people aware of fires as a result of "static" at gas pumps.
His company has researched 150 cases of these fires. His results were very surprising:
1) Out of 150 cases, almost all of them were women.
2) Almost all cases involved the person getting back in their vehicle while the nozzle was still pumping gas, when finished and they went back to pull the nozzle out the fire started, as a result of static.
3) Most had on rubber-soled shoes.
4) Most men never get back in their vehicle until completely finished. This is why they are seldom involved in these types of fires.
5) Don't ever use cell phones when pumping gas
6) It is the vapors that come out of the gas that cause the fire, when connected with static charges.
7) There were 29 fires where the vehicle was reentered and the nozzle was touched during refueling from a variety of makes and models. Some resulting in extensive damage to the vehicle, to the station, and to the customer.
8) Seventeen fires that occurred before, during or immediately after the gas cap was removed and before fueling began.
Mr. Renkes stresses to NEVER get back into your vehicle while filling it with gas. If you absolutely HAVE to get in your vehicle while the gas is pumping, make sure you get out, close the door TOUCHING THE METAL, before you ever pull the nozzle out. This way the static from your body will be discharged before you ever remove the nozzle.
As I mentioned earlier, The Petroleum Equipment Institute, along with several other companies now, are really trying to make the public aware of this danger. You can find out more information by going to http://www.pei.org. Once here, click in the center of the screen where it says "Stop Static".
I ask you to please send this information to ALL your family and
friends,especially those who have kids in the car with them while pumping gas. If this were to happen to them, they may not be able to get the children out in time.
Thanks for passing this along.
FYI:
I imagine it goes without saying that the engine should be turned off. I have some friends that like to fill up without stopping the engine because they feel that it is more convenient and saves wear on the starter.
The PEI study made no reference whatsoever to gender.
http://www.snopes.com/autos/hazards/static.htm
I don't know who decided to add those bits to it and start passing it around or what their motives were. The cell phone bit is made up too.
I was at a gas station filling up and over the PA "Do not use your cell phone while fueling." It was the guy/girl next to me, but come on now, have any fires started because of a cell phone?
I don't believe there are any known instances of cell phone related fires at gas stations. That said, there is a good amount of paranoia surrounding cell phones and gasoline and the lawsuit fearful fuel companies have done nothing to put an end to these fears.
