Save Your S2000 Soft Top
Old Oct 9, 2016 | 09:12 PM
na2king's Avatar
Default Save Your S2000 Soft Top
My link
Don't know if this was shown or mentioned in previous threads, but just wanted to share just in case.
Thanks to Naus!
Cheers!
Old Oct 10, 2016 | 03:39 AM
robertcope's Avatar
Pretty sure you need these: http://www.modifry.com/index.php?rou...&product_id=86
robert
Old Oct 10, 2016 | 05:21 AM
Chuck S's Avatar
Thanks for sharing the roof retraction tip. Requires no effort at all and relieves fabric stress.
-- Chuck
Old Oct 10, 2016 | 08:03 AM
Nerd-Vol's Avatar
I'll give this a try next time I drop the top.
Old Oct 10, 2016 | 08:28 AM
pwrinxs's Avatar
Great thread! I'm in the process of sourcing materials for doing this:
https://www.s2ki.com/s2000/topic/453.../page__st__100
I believe it will help also and it looks pretty good.
Old Oct 10, 2016 | 09:57 AM
pwrinxs's Avatar
Update... Found some good fabric at Hobby Lobby for this project...cost me less than $3.00 for more than enough fabric in case anyone is interested.
Old Oct 10, 2016 | 10:00 AM
Car Analogy's Avatar
But isn't the stress in the fabric limited to the weight of the soft top and its frame, the portions of it that are forward of that pivot point?
That doesn't seem like its that much weight for the fabric. I get that some tops get rips from the frame poking through, but if those sharp edges aren't addressed, even though they are no longer causing a pressure point during lowering, aren't they still an issue with wind buffeting top if you drive top up at speed?
I would think a better fix would be to fixe the pressure points once, not try and male sure to relieve pressure everytime top is lowered.
Old Oct 10, 2016 | 01:32 PM
rpg51's Avatar
I the stress may well be more than just the weight of that front portion of the top. Seems like the angle of pull is extremely shallow - doesn't that increase the pressure over simply lifting it straight up from above? I've tried this a few times with my 02 and I have to say it is very easy to do and it does seem to significantly reduce the stress on the top as it moves down.
I wonder - is it possible to raise and lower our tops manually without using the motor at all?
Old Oct 10, 2016 | 07:08 PM
FromaDB2toanAP1's Avatar
Thanks for the share!
-- Fromadb2toanap1
Old Oct 10, 2016 | 07:13 PM
alSpeed2k's Avatar
Very interesting, quite effortless too!
