Seatback Rattles
Old Oct 22, 2001 | 04:24 PM
Bob Moss's Avatar
Default Seatback Rattles
My passenger seat rattles quite a bit, unoccupied of course. Nothing obvious seems loose, any simple owner-generated fix?
Old Oct 22, 2001 | 04:32 PM
Utah S2K's Avatar
Passenger seat 2 clicks forward...but the rattle comes from the seat belt not the seat; if it rattles give a swipe so the metal isn't hitting the door.
Utah
Old Oct 22, 2001 | 04:44 PM
yu888's Avatar
I keep the seatbelt fastened on the passenger seat while it is unoccupied. Fixed the rattle that I had. Hopefully its just that. Otherwise... Good luck!
Old Oct 23, 2001 | 06:30 AM
Fed's Avatar
Fed
Actually, it's a little more than a rattle, more like the whole seat shakes and vibrates, especially on bumps. I have that problem too.
Old Oct 23, 2001 | 10:23 AM
wanabe's Avatar
since there are several types of rattles that have been identified in the cockpit, it might be easier to help you if you could give more specifics...
can you i.d. where on the seat the rattle is coming from?
what does it sound like?
same boot on and boot off?
same rattle with the seatbelt fastened or loose?
no change if the seat position is changed?
Old Oct 23, 2001 | 10:49 AM
Bob Moss's Avatar
I am reasonably sure it is the sear back....not the belt. I have checked the seat mounting at the rail and it is solid. I believe it is from the back itself and happens on fairly smooth roads, but it is related to suspension movement
Old Oct 23, 2001 | 12:33 PM
MarkS2K's Avatar
My passenger seat rattles when I go over bumps too. Only thing you can do is make sure it's wedged all the way back.
Old Oct 23, 2001 | 12:53 PM
jschmidt's Avatar
Before you dismiss the idea, try this. Take the blade part of the seatbelt and insert it in the keeper at the top of the seat. Just flip it over and slide the blade part into the keeper. You've just eliminated the most common rattle. Then see if you can duplicate the other part.
BTW, my method has the same result as fastening the belt but leaves the seat completely open for your makeup, curling iron, or electric shaver.
Old Oct 30, 2001 | 10:02 PM
enguyen7292's Avatar
I also experience a rattle when going over bumps...it's gotten worse though, I can hear the rattle right at startup as the car shakes. The interesting thing is that after numerous atempts to confirm that it was indeed the seatback...I tried putting some pressure on the bottom seat cushion while driving over bumps and noticed the rattle was gone. It seems as though there is some vertical play in the seat itself....not really sure how to fix it.
Old Oct 30, 2001 | 11:02 PM
Colin's Avatar
I keep the seatbelt fastened whenever the seat is empty. Also make sure the back of the seat is not hitting the roll hoop cover. This is a common cause for extra noise. Also make sure your spare tire is securely tightened. It's in the trunk and right behind the passenger seat.
