seized caliper
Old Oct 25, 2009 | 01:51 PM
21k's Avatar
21k
Default seized caliper
so i take my car to honda for a grinding noise and my rear caliper is seized and my brake pad is cracked and it desrtroyed my rotor. so i need new pads and rotors and he says i need to replace both the rear calipers so they are the same strength. im out like 1500 and it sucks and felt like posting here
Old Oct 25, 2009 | 03:13 PM
CKit's Avatar
Well, that sucks because your mechanic bent you over.
This is why a $20 membership on s2k is useful.
1. There are tons of used calipers for sale. I bought a full spare set for $100 USD.
2. Replacing pads and rotors takes maybe 1-2 hours with basic hand tools.
I would have just replaced one caliper with a used one for $50 and maybe replaced both rear rotors and pads. ~1 hour of time in your garage and <$200 in parts. Even less if you bought some used OEM pads. I picked up a half worn full set for $50.
Old Oct 25, 2009 | 08:31 PM
GT_NFR's Avatar
You really got hosed. for $1.5K you're well on your way to a used set of BBKs.
Old Oct 25, 2009 | 09:46 PM
spook's Avatar
Spoon rotors went for $800 on here recently :/
Old Oct 26, 2009 | 01:09 AM
21k's Avatar
21k
shit, sucks for me. i dont have a garage to work in or even a floor jack. i wish i could do it myself cause they are probably charging me bunch for labour. they want to charge 300 for a valve adjustment, is that a ok price? i have a knocking and they said its too loud to tell if its from valves or tct.
Old Oct 26, 2009 | 05:41 AM
patinum's Avatar
You might also want to make friends with any local area S2000 owners. I've been helped by and have helped several people in my local s2k community. I imagine it's saved me quite a bit of money - especially when I didn't have a garage (although that's not the reason I'm active in my local community). If you were local, I'd help you switch out your pads and rotors for a case a beer (and not a $1500 case )
Rule 1) Local owners are usually friendly.
Rule 2) Mechanics are usually jerks.
Rule 3) Rule 1 overrides rule 2.
Old Oct 26, 2009 | 07:19 AM
CKit's Avatar
Yeah, totally. How do dudes hang out, otherwise? Last Spring a buddy came down, we drank beer, and magically the brakes the were done and the fluid flushed.
Old Oct 26, 2009 | 08:59 AM
jeggy's Avatar
should i be
or should i be
Old Oct 26, 2009 | 09:06 AM
patinum's Avatar
Originally Posted by jeggy,Oct 26 2009, 10:59 AM
should i be
or should i be
Old Oct 26, 2009 | 03:53 PM
vollrathian's Avatar
ya u got pwned, local s2ki community ftw find a friend that knows what he is doing and you're set, a case of beer works wonders
