Which set up should I go with?
Old Mar 20, 2006 | 09:02 PM
Hamiy's Avatar
Default Which set up should I go with?
I was thinking between
17" Bronze Work Emotions
Cheaper tires (Kuhmo MX type)
4.57 Gear BUT without the reinforced differential.
OR
Ap1 Wheels
S02 Tires
Minor bolt ons (AEM V2, test pipe)
Tuning (VAFC II)
My question that doesn't involve an opinion- will I be able to use the gears without a reinforced differential? Will reliability be sacrificed?
I really only want to go with gears with the bigger heavier wheels to make up for it. If I am not running these I would like to keep the highway rpms down and just get some extra kick with boltons
Handling is very important. How much will the heavier 17" Work wheels effect handling? Also, the S02's vs. cheaper tires will also effect handling. I am planning on auto-x the car in Street modded class. I drive aggressively, most of the time I will be running through a twisty road, so I would like to know a good set up.
But then looks come into play Ap1 rims look so bland, and the Works have a great look to them. The bronze looks great on black.
Just looking for some suggestions Thank you
Old Mar 20, 2006 | 09:08 PM
Nobody's Avatar
Take whatever rims you have and put a set of Toyo RA-1s on if handling/performance is your number one priority. If you want looks and performance, look no further than CE28s w/RAs.
Old Mar 20, 2006 | 09:20 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Gears.
Old Mar 20, 2006 | 09:21 PM
kayvan_pour's Avatar
Banned
wheels, and the kuhmo mx is a great tire
Old Mar 20, 2006 | 09:24 PM
Hamiy's Avatar
Of course everyone suggests gears, but I don't know if I can run them without a reinforced differential. I'm not looking at spending that much money so...
Old Mar 20, 2006 | 09:29 PM
Yes you can,no problem.
Old Mar 20, 2006 | 10:02 PM
SilverKnight's Avatar
Advans RG IIs 18s
Old Mar 20, 2006 | 11:17 PM
INFMS's Avatar
A nice wheel combo that doesn't weigh more than OEM's. Gains with the set-up you mentioned are very minimal, and in my opinion, not worth investing into.
Kuhmo Mx's offer great performance and wear for the money.
Good luck with whatever you choose.
Old Mar 20, 2006 | 11:51 PM
batikan's Avatar
definitely get the gears. it is the best thing i did to my car. actually the second best because the first the the SC
Old Mar 20, 2006 | 11:57 PM
xdavieexx's Avatar
unless you are going to track the car, i don't think you would want to go with Ra's they have 180 threadwear and thats not going to last very long. Go with T1R's (280) i just got them and though they are not as good as S02's(pretty close), but they are better in the rain.
