Shifter vibration while coasting. Is that normal.
Got a 2006 s2k yesterday. Shifter vibrates while coasting but not when accelerating. The car body is not vibrating. Didn't notice this during the test drive. Also there is a distinct jerk when Istart the car in neutral.
Wanted to know if this is normal?
The shifter will definitely vibrate a bit. Replacing the OEM knob with a voodoo knob from Ricks definitely helped a bit, but its still there if you hold the knob and feel for it. Don't try to hold it still, supposedly this is bad for it (the gearbox I believe?).
As for the starting in neutral, not really sure. Doesn't ring a bell but I could just not understand what your describing. Relax, you got a lot of warranty left! Congrats on the new car!
Originally Posted by ammo1199,Jun 9 2006, 11:07 PM
Thanks. That means its normal.
What i meant was when starting the car in neutral I hold the shifter in my hand and I feel distinct jerk. Please note that my previous car 00 si did not behave this way.
the slight vibrate is normal, if you getting some bad vibration, the plastic holder might be cracked.(the other end of the shifter)
someone on Honda-tech(one of the FR MOD guy) removed his/her shifter and found out the plastic holder/cap was broken into pieces.
The best way to check is to take it out, you want to regrease it once a while anyway
Originally Posted by Emil St-Hilaire,Jun 10 2006, 12:45 AM
The best mod you can get to solve this problem,is a SS(R.P.)from Rick's.
correct me if i am mistaken
Originally Posted by iam7head,Jun 10 2006, 04:31 AM
The Si don't have a shifter directly sit in the transmission like the S does.
Rick's has worked to exhaustion to fix the ringing problem with the SSer.. not sure if its been completely eliminated, but I imagine it has
I actually like the feeling of the vibration ... it makes me feel connected with the car
You should check out those Best Motoring videos -- the shifter looks even scarier in those videos (they look like the shifter was about to pop out)!!!!
