Shifting
Old Jul 16, 2014 | 05:13 PM
Chuck S's Avatar
Default Shifting
Yep, shifting!
Not a question about where the gears are or shift points but I need some insight/advice on engine rpm when shifting. The 2000s engine seems to have no flywheel at all. The second I lift off the accelerator and depress the clutch the engine seems to drop to idle and the shift makes me look and feel like a guy who can't drive. Is there a sweet spot on the gas pedal when shifting during normal driving or to I just have to keep experimenting?
-- Chuck
Old Jul 16, 2014 | 07:41 PM
JulieU's Avatar
Administrator
Probably just need to practice shifting a little faster, minimizing the time that the clutch is engaged.
I fixed your signature BTW.
Old Jul 17, 2014 | 06:39 AM
DrakeValle's Avatar
Agreed. Don't hold the clutch in so long that the engine drops to idle. If you do, blip the throttle to get the revs up and then release the clutch.
Old Jul 17, 2014 | 07:10 AM
JulieU's Avatar
Administrator
Here's an idea... find another S2000 owner local to you, preferably someone who has had theirs a while, better yet someone with proper track experience, and take a ride with them. Watch and learn how they clutch/upshift/downshift/throttle. That's how I learned all about rev matching.
Old Jul 17, 2014 | 07:12 AM
DrakeValle's Avatar
Doesn't really even need to be an S2000 owner to learn all that, but it's always a plus
Old Jul 17, 2014 | 07:36 AM
kevinS2OOO's Avatar
I normally let go of the clutch quickly and then slowly at the end of the clutch point. Second gear is a little (as always) harder to master though.
And it's smooth.
Old Jul 17, 2014 | 08:50 AM
Not Sure's Avatar
Could be that you're lifting the accelerator before the clutch is fully disengaged - you'll get a slight engine braking effect and RPMs will drop. Just drive it more to get familiar with the clutch/throttle timing.
Old Jul 17, 2014 | 04:24 PM
bgoetz's Avatar
4300rpm no less
Old Jul 17, 2014 | 04:27 PM
Chuck S's Avatar
Thanks, several things to try.
-- Chuck
Old Jul 17, 2014 | 04:48 PM
Ryuu's Avatar
we have a clutch in this thing...
