Shifting with A/C on
Old May 7, 2004 | 12:19 AM
ThaWyze1's Avatar
Default Shifting with A/C on
I bought my car during the cool weather, so I haven't had to turn on the A/C until now recently. I've noticed that you need higher rpms after you shift when you have the A/C turned on. Like after the shift is done, the rpms will have dropped, but it will require a higher rpm than what it is at after I shift, so the car will bog. I hope that makes sense. If I give it some gas before I let go of the clutch, it helps, but not every time... especially with the 1-2 shift.
Has anyone experienced this? Does anyone have a technique or know of some tips to shift better?
Old May 7, 2004 | 02:19 AM
jguerdat's Avatar
At low RPM, less torque is being generated to the parasitic drag on the engine is more noticeable. Higher RPMs put the engine in a better position to handle the drag.
Now, if you mean that the engine actually bogs/hesitates, that's a different matter. If this is the case, you should have the dealer check it out because that's NOT normal.
Old May 7, 2004 | 03:30 AM
Elizer's Avatar
the ac robs the car of power im pretty sure, it would be a lot worse on a turbo car....
i know what ur talkin abouut
Old May 7, 2004 | 10:54 AM
ThaWyze1's Avatar
Have you experienced it before in the s2k?
Old May 7, 2004 | 12:17 PM
Driv300mph's Avatar
if you're steady on the gas in a particular gear, I just feel that it gets a bit slower with the gas in the same position... thus requiring more throttle input, using more gas to compensate for the power "robbed" from you engine by the A/C
Old May 7, 2004 | 01:02 PM
mikdys's Avatar
Turn it off and open the roof!?
Old May 7, 2004 | 04:00 PM
MattG's Avatar
On a side note - you should run the A/C at least once a week to keep it (seals etc) in good working order.
Yes the A/C uses more engine power. In fact the new Lotus Elise automatically cuts the A/C off under heavy acceleration for better performance.
Try shifting at a higher rpm point compared to what you usually do. Accelerate more before you shift (ie shift when revs are going up), not when you are holding a constant RPM.
I have a little habit of leaving a longer gap to the car in front of me in traffic. This way I can speed up just before I shift to get the RPMs to the point I like.
Old May 7, 2004 | 04:09 PM
Russ's Avatar
Most cars today (at WOT or pre-determined RPM) shut the A/C off unless I'm
mistaken. This car bogs off the line with the a/c on, hot weather and mild rpm
starts from a slow roll or stop (1000 rpm or lower). This engine puts out some
SERIOUS heat and the a/c on just makes things worse when you're trying to
leave a stop in high temps from say 1200 rpm. You've got to rev that dog.
As for the unit itself, it is one of the least effective a/c units I've ever seen which explains why Honda offers us a removable top.
Truly domestics have it all over imports when it comes to a/c units. My Ford Contour
SVT could keep meat frozen if you had it on full speed, coldest setting.
Old May 8, 2004 | 05:39 AM
mikdys's Avatar
[QUOTE]Originally posted by Russ
mistaken.
Old May 8, 2004 | 07:48 AM
RazorV3's Avatar
doesn't help its 90 degrees outside with 100% humidity. those leather seats don't help at all especially if its very sunny out.
