Side Duct Airflow System
Old Aug 18, 2001 | 04:14 PM
axcilla's Avatar
An inexpensive procedure to make the faux side vents fuctional. Introducing the Side Vent Airflow System.
More pictures Available at:
http://www.hondas2000accessories.com/S2000airflow.htm
Tell us what you think an easy way to cool the engine,increase airflow and make the faux side vents useful.
What do they do now
Regards,
David McCune Jr.
Old Aug 18, 2001 | 05:44 PM
Eze8199's Avatar
Can you show a whole front view of the s2k with those side vents on?
Old Aug 18, 2001 | 05:55 PM
amartin's Avatar
Unless you run tubes to the air intake, I doubt there is any performance gain or cooling gain at ALL from this. Personally, I'de rather have ducts to cool by breaks if I'm doing to do this mod w/out tubs.
$.02,
Aaron
Old Aug 18, 2001 | 06:20 PM
axcilla's Avatar
This modification can be used with breake ducting, as the brackets are a great way of attaching the tubing for the brake ducting. The difference in temperature on the radiator and air cleaner is almost the same using the hoses.
The purpose is to make the side vents useful, and increase air flow.
I'll post a pic tommorow.
Regards,
David McCune Jr.
Old Aug 18, 2001 | 07:05 PM
cdelena's Avatar
I use the grills on my brake ducts..
Old Aug 19, 2001 | 12:39 PM
axcilla's Avatar
Thanks for the photo Chris,
axcilla
Old Aug 19, 2001 | 08:07 PM
pcloadletter's Avatar
What's up with the 5/32 hex wrench? I thought our car used metric hardware.
Old Aug 20, 2001 | 07:23 AM
johev's Avatar
What is the easiest way to cut these out??
Old Aug 20, 2001 | 07:47 AM
axcilla's Avatar
The 5/32 hex wrench is used with the brackets that are added to the S2000.
The easiest way to cut these side vents out is with a DREMEL Tool. That is what we have used to make modifications on the S2000.
Regards,
David McCune Jr.
Old Aug 20, 2001 | 07:49 AM
johev's Avatar
Thanks David!
