Side strake hardware
Old Dec 2, 2004 | 11:15 PM
TheTaxGuy's Avatar
Thumbs up Side strake hardware
Hello,
I purchased a pair of strakes from a fellow member and was in the process of installing it when I noticed that I would need additional parts. upon talking to the Honda dealer locally I found out the the small parts (i.e. butyl o rings, plugs and gromets) were only part of a set. Where would I go about getting this stuff individually. And no, Home Depot does not carry these items.
Thanks
Old Dec 3, 2004 | 04:49 AM
LouisM's Avatar
May I ask what side strakes are? I have seen the term several times, but don't know what it refers to. Thanks.
Old Dec 3, 2004 | 09:02 PM
TheTaxGuy's Avatar
Side strakes are the OEM option for a side body kit...Is just a little peice that goes in front of the two rear wheels.
Old Dec 3, 2004 | 09:04 PM
TheTaxGuy's Avatar
Any pointers people???
Old Dec 3, 2004 | 10:54 PM
SIIK2NR's Avatar
I had the same problem when I took mine off to remount them. You really only need the push pins and the screws for the back side. Lowes carries that kind of stuff.
Old Dec 3, 2004 | 11:43 PM
Ooalloems2koO's Avatar
there is always a jeff from hardtopguy.com u can talk to anytime regarding anything about S2000
Old Dec 4, 2004 | 07:13 AM
xviper's Avatar
The fastener that goes into the hole on the underside can be replaced by a common drywall picture hanger. These are the things that when you put it into the hole and begin turning the screw, the sides of the cylinder squeeze out and hold the fastener from behind the (in your case) the car's sheet metal.
However, the one that goes into the hole on the side of the car is the tough one. It is a very unique kind of fastener that comes in two parts. The first part gets installed in the hole and second part gets "hung" onto the backside of the strake. You then line up the strake so the two parts line up and you push to "snap" the one part into the other. This serves to both hold the strake up against the car and it also spreads the bit in the hole so it doesn't pull back out.
Without this part, you are left with few options. One of which is to build up layers of double sided autotrim tape on the back side of the strake so that when you press it onto the side of the car, it sticks flush. Make sure you clean off the areas to be stuck to really well with alcohol.
These are the only pieces of hardware that are not easily salvageable when the strakes are removed. The rest should come with the strakes.
Old Dec 5, 2004 | 02:49 PM
TheTaxGuy's Avatar
Could the strakes eventually work their way off over time or is the bond pretty tough?
Thanks xviper
-Shawn
Old Dec 5, 2004 | 04:11 PM
xviper's Avatar
Thanks xviper
-Shawn
The strakes are held on at several places. That one on the side of the body serves to mostly hold the strake flush with the body. There is a bit of a spring action to the strake such that it does not rest flush to the body on its own. That's what the mounting pin and double sided tape is for. Double sided tape for automotive use is pretty strong stuff as long as you clean off both surfaces very well. Even if the strake lost adhesion with the body surface, it is still attached by the 3 hooks to the bottom strake sub-structure. That same sub-structure also holds the strake in a couple of places at the rear edge, too. You can lose it but it's not easy unless you hit something with it.
This is what I used for the anchor under the car:
See those little sharp, pointy things just under the screw head? I squished those flush so they didn't cut into the car.
Old Dec 5, 2004 | 06:08 PM
SIIK2NR's Avatar
The side skirts are essentialy ruined after installing the side strakes due to the drilling a hole in them. The factory gromets or push pins suck ass. If you replace them with the dry wall screws or whatever.....I recommend after you get them in place to put a small bead of super glue on the rubber gasket on the edge of the strake. Once the glue touches the side skirt it will create an airtight seal and it won't come off. Trust me it works........
Keith
Mar 1, 2009 05:42 PM
tekknikal
Dec 16, 2008 07:07 AM
wazpe
Jul 24, 2007 12:05 PM
wazpe
Jul 24, 2007 12:24 AM
pittpanther
Jul 21, 2001 01:02 PM
