Slight Rattle in MY05 Brand New...
Old Aug 31, 2005 | 06:37 AM
x mj x s2000's Avatar
Default Slight Rattle in MY05 Brand New...
I have a 2005 with 1K miles on it, and there is a slight rattle coming from the driver side when the top is up. It is very suttle, but also very annoying. Anyone have a similar problem or a good solution? Thanks in advance.
Old Aug 31, 2005 | 07:29 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Better get used to it.!!!
It won't be the only one;Hey,this is a " SPORTS CAR " !!!
Old Aug 31, 2005 | 07:42 AM
WPS's Avatar
WPS
Clicking noise?
Old Aug 31, 2005 | 07:47 AM
[QUOTE]Better get used to it.!!!
That might be the dumbest statement I've heard in a while.
Anyway, yeah, it's a clicking coming from somewhere near the top on the driver's side. I just can't pinpoint it.
Old Aug 31, 2005 | 07:48 AM
Mark16q's Avatar
I'd bet it's coming from the soft-top latches. Mine rattle and buzz despite various efforts to stop it. The only effective method thus far is holding my finger on the stupid thing. So now I roll the window down a bit....and the noise is gone. Mine also rattle when the top is down, only noticeable at low speed so not a big annoyance.
Mark
Old Aug 31, 2005 | 07:49 AM
topcat7111's Avatar
My use to do that...than over time the slight rattle went away..Now i leave the top down most of the time...
Old Aug 31, 2005 | 07:56 AM
superjimbo's Avatar
https://www.s2ki.com/forums/index.php?showt...85670&hl=shinsu
Try using Shin Etsu grease to lube up the seals. This seems to be a common solution to hardtop squeaks so perhaps it would work for your soft top. Not sure if this solution applies to soft tops, but I thought I would throw it out there in case it did. If any of you know better, please correct me. Good luck!
Old Aug 31, 2005 | 08:15 AM
[QUOTE=x mj x s2000,Aug 31 2005, 10:47 AM]
Hey A**hat,you didn't buy a MAYBACH.!!!
Old Aug 31, 2005 | 08:58 AM
Am I the only one? it's not the latches, it's something else.
Old Aug 31, 2005 | 09:03 AM
SheDrivesIt's Avatar
Check to see if it is the joints in the structure over your head.
