Small Instrument Cluster Issue
Old Mar 18, 2008 | 08:30 AM
rikhemi's Avatar
Default Small Instrument Cluster Issue
Well, just installed modifry's dash braket which looks great. But as I completed this process, I turned on the car and saw that in the instrument cluster, the left side of the cluster is a bit darker than the right side. The back light of the cluster is fine(rpm, temp, etc). To compare, if you put the settings to your cluster to be the darkest, thats what it looks like on the left side. The middle and right is fine. Its not that big of a deal but if its something I can replace(bulb), I don't mind doing it.
Any suggestions,
Thanks,,
Old Mar 18, 2008 | 02:04 PM
Rdizzle's Avatar
Sounds like one of your bulbs went out. I just replaced one of the instrument cluster lights in my parents' CRV over the weekend. It only took about 20 minutes to do so it's pretty easy.
Might be a DIY somewhere...
Old Mar 18, 2008 | 02:59 PM
Rdizzle's Avatar
Here's a DIY to remove the cluster:
https://www.s2ki.com/forums/index.php?showt...0&#entry8419961
Old Mar 18, 2008 | 04:45 PM
rikhemi's Avatar
Oh great.. Thought I might need a new cluster or have to deal with it.
Where did you get the bulb at honda or is there somewhere locally you can buy it at..
Thanks..
Old Mar 18, 2008 | 08:22 PM
Rdizzle's Avatar
I bought mine at Schuck's. I just brought my burnt out one in and showed the guy there which bulb I needed. I would've went to Honda but they were closed.
Old Mar 19, 2008 | 05:38 AM
rikhemi's Avatar
Thanks for the info..
But for some reason, when I drove last night in the car, the issue corrected itself. Its the strangest thing. Now everything lights up normally.
I guess the car fixed itself..lol..
Old Mar 19, 2008 | 08:02 AM
nakdboardr's Avatar
Check the connection maybe it is loose
omgvtec
Sep 3, 2015 02:29 PM
hardcorehom
Apr 16, 2012 02:36 PM
tehsu
Jan 4, 2011 01:39 PM
cubide
Jul 14, 2007 02:20 PM
MB06
Feb 24, 2004 02:59 PM
