Spoon or Brembo?
Old Jul 23, 2006 | 11:31 PM
LemonS2k's Avatar
Default Spoon or Brembo?
Planning to change brake soon. Which one performs better, both 4 pot... brembo has 13 inch cross-drilled rotor, spoon comes with monoblock design and 12 inch rotor... can't decide which one to go for...
also, which one has better clearance?
I have a Volks CE29N 17 x9 +63 setup ... planning to use 10mm spacer with the bbk...
Old Jul 24, 2006 | 09:17 AM
dmz's Avatar
dmz
There is no comparison. Brembo kit is just a better performing kit than the Nissin made Spoon kit. The only advantage that I can think of is that the Spoon calipers are smaller and should give you more clearance for more variety of wheels without using spacers. of course, if you insist on JDM then Spoon is your only option.
Old Jul 24, 2006 | 10:07 AM
circa86's Avatar
why is Spoon his only option?? and if you say Brembo kit is better atleast provide some info as to why. is that your opinion or have you had experience, etc. etc.
Old Jul 24, 2006 | 10:14 AM
44Runner's Avatar
What are you hoping to get out of your new brakes?
Old Jul 24, 2006 | 10:48 AM
Ks320's Avatar
10mm space is pretty aggressive!
I say go for Spoon --> more JDM feel!
Old Jul 24, 2006 | 11:31 AM
-KEY!S2K-'s Avatar
ENDLESSSSSSSSSSSSSS
Old Jul 24, 2006 | 11:54 AM
klee1113's Avatar
c'mon, reading comprehension.
Old Jul 24, 2006 | 11:56 AM
circa86's Avatar
so Endless, Project Mu, aren't jdm???? Amuse, J's Racing . . . . .
do you comprehend that??
I'd say Endless is about as good as it gets, unless you can afford the really really really nice Brembos.
Old Jul 24, 2006 | 12:29 PM
dmz's Avatar
dmz
The original poster did only mentioned 2 options. So the only JDM out of those 2 options is Spoon...
Yes, I've had Brembo on my other cars and Brembo are more performance oriented and they are more dominant on the racetracks while Nissin who makes Spoon are more focused on cheaper OEM applications. He also did mentioned that the bembo had 13" rotors and the Spoon had 12". More surface metal for heat dissipation = better performing brakes.
Old Jul 24, 2006 | 02:37 PM
PdC's Avatar
PdC
Spoon are super light tho, and unsuspended weight loss can be a major perfomance gain.
