Spoon engine
Old Oct 17, 2001 | 08:49 PM
tze's Avatar
tze
Default Spoon engine
Refer: https://www.s2ki.com/forums/showthread.php?...?threadid=30779
Now own up, who bought this engine?? Give us info, pics, details. please please NOW!!!!!!!!!!!!!1
Old Oct 17, 2001 | 09:11 PM
mingster's Avatar
ok ok ok, i'll confess
i didn't get it.
Old Oct 17, 2001 | 09:24 PM
gregstevens's Avatar
Banned
What did Spoon do to the motor? Can anyone elaborate on the specifics?
Old Oct 17, 2001 | 09:57 PM
reecespieces's Avatar
engine balancing would be one. Not sure if the engine Giampiero was selling had the spoon internals or not. If it did then it would have cams, higher compression pistons, valves, valve springs, baffled oil pan, I think a reworked head, larger tb. And it also comes with different gearing in the tranny. I think I missed a lot of stuff, but basically, Spoon probably threw in everything they have.
Old Oct 17, 2001 | 10:05 PM
Schatten's Avatar
for 7500 TB to output shaft, that's not a bad deal at all! =)
Old Oct 18, 2001 | 03:27 AM
Pinky's Avatar
The question is.................what kind of power does it make over stock!
Old Oct 18, 2001 | 06:05 AM
JRM's Avatar
JRM
265 Horsepower! Hand assembled motor!
Old Oct 18, 2001 | 06:14 AM
Swurvydel's Avatar
how much does it run? why not just get the supercharger or turbo?
Old Oct 18, 2001 | 06:19 AM
JRM's Avatar
JRM
$7800 - $8500 depending where you by it!!
Old Oct 18, 2001 | 07:23 AM
netwiz's Avatar
the Spoon motor makes ~265hp at the crank. It's a balanced and blueprinted rotating assembly (crank, con rods, pistons) w/ the 12.2 cr lightweight pistons. That's it. My guess is that w/ cams, the high CR gasket, headers, ported heads, and a good valve job, you could see north of 300 crankshaft HP from this motor.
now, _that_ would be cool!
