spoon style intake?
Old Apr 27, 2004 | 09:31 PM
s2kbtheway's Avatar
Default spoon style intake?
is there any companys that make a spoon style intake out there ?
-mike
Old Apr 27, 2004 | 09:53 PM
reds2's Avatar
check Muz' thread in the Group Buys section
Old Apr 27, 2004 | 09:59 PM
dayves2k's Avatar
I got this one off of Ebay for about 180 shipped from Japan.....just as good as far as construction
Old Apr 28, 2004 | 05:48 AM
VFROOOM's Avatar
Here is my write-up on the Spoon Knock-off from HK. Probably the same unit as Daves2k.
Snorkle Thread<---CLICK
Old Apr 28, 2004 | 07:17 AM
reds2's Avatar
dayves,
What kind of radiator plate is that? One of DarkKnights?
Old Apr 29, 2004 | 06:59 AM
dayves2k's Avatar
Originally posted by reds2
dayves,
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=46098
~then I just cut the hole for the snorkel
Old Apr 29, 2004 | 07:37 PM
reds2's Avatar
Fitment? How hard was the CF to cut? Can you reuse your weather stripping?
Old Apr 30, 2004 | 05:35 AM
dayves2k's Avatar
I drilled a hole on each corner of a measured square that would accept the snorkel then I used this rigged up saw
to cut the rest....then sanded etc.... yes you reuse the weather stripping.....but not the metal stripping under the weather stripping...the CF cooling plate will take place of the thickness of the metal stripping so it is not needed and if used you will not be able to close your hood properly.
side note: the CF Cooling plates are very thin so it is easy to cut but it is also easy to mess up the cut.
zebidi
Jan 31, 2015 06:27 AM
kchandra
Nov 27, 2006 08:17 AM
Saud2k
Dec 7, 2005 12:45 PM
aznprydefloz
Jul 23, 2005 11:21 PM
ludeslip
Sep 29, 2003 05:20 AM
