spoon x-brace.
Old Feb 13, 2006 | 09:21 AM
Irace4Kimchi's Avatar
Default spoon x-brace.
hi.
im going to install my spoon x-brace this week. is there anything i need to know? is this 100% bolt on? (no cuts on plastics?)
i have all the bolts.
thanks for reading.
Old Feb 13, 2006 | 09:23 AM
Shadow_S2K's Avatar
Former Sponsor
Its just a bolt on, nothing is cut or removed.
Old Feb 13, 2006 | 09:43 AM
S2kracka's Avatar
Took me about 5 minutes to install, very easy to do!
Old Feb 13, 2006 | 10:23 AM
Nimbus's Avatar
Untighten 4 bolts, place x-brace, tighten back 4 bolts. DONE!
Old Feb 13, 2006 | 11:10 AM
thanks for the information.
if its that easy then ill probably do it tonight when i get home.
Old Feb 13, 2006 | 11:11 AM
S2kracka's Avatar
Close
Remove 4 stock bolts, put up x-brace, install 4 aftermarket bolts. To add some excitement I recomend slamming your head on the x-brace then punching the oil pan as hard as you can. Not only will it make you look tough, hopefully you'll get some sympathy affection from your g/f and/or wife afterwards
Old Feb 13, 2006 | 11:12 AM
news2kroller's Avatar
just make sure you position it at the right corners, they look the same but it will only fit one way, it took me like 10 minutes before i realised the arms were not the same size.
Old Feb 14, 2006 | 10:56 PM
SenderGreen's Avatar
Do not install the X-brace one side at a time. I have read on the forum that someone did this and was concerned that over time his chassis became deformed. Jack up the whole front end at the same time and use Jack stands. I think I remember Xviper saying that ideally an X-brace should be installed with the suspension loaded if possible.
Also use proper torque specs for the brace, for the Spoon they say 4.0 kgf.m. I think thats about 29 ft lbs. The stock bolts that are removed have a torque spec of 3.9 kgf.m or 28 ft lbs. Good Luck
Actually, if it is a new X-brace and you plan on having it on the car for a while, you may consider getting some gloss black rustoleum to spray the insides of the brace's re-enforced center area. Good Luck again
atlxkevinx
Feb 20, 2008 07:00 PM
Rio S2K
Jun 28, 2006 11:56 PM
Rio S2K
May 9, 2005 07:21 AM
kevsS2
Feb 2, 2005 03:21 PM
charlie
Feb 27, 2001 07:43 PM
