Squeal from brakes
Old Aug 19, 2005 | 06:58 AM
themush1326's Avatar
Default Squeal from brakes
I just got my CPO 02 s2K and I hear a seualing sound when I press the brake pedal, Its more pronounced when I lighly press the pedal, less so when heavy.
Also when I take off from a stop and just let out the clutch w/o pressing the gas I
hear a rattle form the engine compartment
I'm going to the dealer later but any ideas?
Old Aug 19, 2005 | 07:02 AM
Paul S's Avatar
Your brake pads need a little lube. Autozone carries them and it's pretty easy to apply. (on the back of the pads, not where they touch the rotor)
Also, how do you take off from a stop without pressing the gas? The rattle is probably the sound of your engine stalling.
Old Aug 19, 2005 | 07:03 AM
TubeDriver's Avatar
They are either worn (anti-squeal indicator is engaging rotor) or you have track pads?
Old Aug 19, 2005 | 07:05 AM
thanks
I meanty lightly pressing the gas, like when I pull into my garage.
Just letting out the clutch and lettting the car move foward.
Old Aug 19, 2005 | 07:07 AM
The car is a CPO so they are supposed to replace if worn, thats whats worrying me
Old Aug 19, 2005 | 09:32 AM
hpark's Avatar
why don't you take a look to see if the pads are worn.....i distinctly remember you could see the pads on this car without jacking the car up or removing the wheel....(at least on one end of the car)
Old Aug 19, 2005 | 01:47 PM
Brownergy's Avatar
My car's brakes a starting to squeal as I come to a stop at low speeds, pads and rotors look good though, having Billman check it out tomorrow.
Old Aug 19, 2005 | 01:54 PM
I'm going in Tuesday, we'll see.
Old Aug 24, 2005 | 10:03 AM
dealer says pads are aftermarket and are 90%, no problems other then sound.
Is this normal for aftermaket pads.
Dont want to replace pads if they're good.
Any ideas?
Old Aug 24, 2005 | 10:20 AM
Paul S's Avatar
Depends what kind of pads they are. I had some Axxis Ult, and although they're supposed to be one of the quieter AM pads, they still squeaked noticably. If it really bothers you, either you or the dealership can put some of the anti squeak lube on the pads. If it's still bothering you, you probably will have to change out the pads.
