Stability of the S2000
Originally Posted by spectre240sx,Mar 25 2009, 08:23 AM
I'm amazed to hear that about the EVO. It's not much heavier than the S2000... I'll definitely keep that in mind.
Why the S2000 is better than an Evo
Originally Posted by dimi,Mar 21 2009, 11:17 PM
No it's not. The early AP1s have a rear biased suspension where the rear spring stiffness is quite a lot higher than the front. The opposite is true for 02-03 and even more so on AP2 (excluding CR).
I have on 01. The car handles very well and has high limits to its handling. What I have found though is that when you reach those limits the rear tends to give, suddenly too. If you react quickly you can catch it, but this is not one of the cars that you go drifting with or power slide out of corners. A very rigid chassis and little torque do not make a good drifting car from my understanding.
I had an Evo IX MR.
I think they are understating its handling abilities. It handles fantastically, what killed me with that car is the build quality. The engine, suspension etc is fine but the rest of it is Mitsu garbage. Just typical bad engineering on Mitsubishi's part. Leaks, poor fitment, you name it. I saw a new one at my mechanics a few months ago and the rear window wasn't even straight.
Might want to check out a STI or WRX, much better built cars and they handle pretty damn good. I had a 2004 sti, it was built like a brick. You just couldn't kill it
Originally Posted by energetic,Mar 25 2009, 05:27 AM
Read the following article as well, and I bet this topic will get even more interesting.
Don't want this to turn into an evo/sti vs S2000 debate. But if you take A-Stock at face value, you could deduce the S2000 handles better. I mean, it has a worse power/weight and torque/weight ratio (I think, haven't done the numbers), but still dominates A-stock. Additionally, I've seen some pretty bad drivers get good times in an evo/sti with a point/shoot driving style.
Anyway.
OP - what is the price range you're looking for? There are plenty of other roadsters out there that are more "stable" - M Roadster, Boxster, Solstice/Sky GXP/Redline, Miata, SLK. But there are increasingly less lightweight rwd cars around. I will say that while the S2000 isn't for everyone, if you learn to drive the car properly, it is an incredibly fun car. I don't think of the s2000 as instable anymore, I think of it as a car that is willing to turn when I tell it to.
Anyway.
Originally Posted by Vik2000,Mar 25 2009, 12:21 AM
engrish?
On another note, I think the VSA saved me from spinning once, as I was merging onto a bridge in the rain. I probably got on the throttle a little too soon, I could feel and see the VSA go on. I too leave the VSA on most of the time.
Originally Posted by Nickamsweet,Mar 21 2009, 10:08 AM
I feel like at higher speeds the car seems very unstable!! like 110-120+ (i stop at 120) it seems like the car rises up... and it seems unstable as any slight braking feels it's going to spin out and flip...
