Steering ratio and turn-in
Old Aug 31, 2007 | 07:59 AM
boofer's Avatar
Default Steering ratio and turn-in
i looked at the specs and the S2000 has a higher (slower) turning ratio than my last car, a TSX. is that really true? also, there seems to be a little more play with the wheel when i'm going straight. is this for more straight-line stability at high speeds, and less twitchy steering? i'll admit i've never driven an AP1 (i have a 2007), and i've heard rumors that the whole setup was more twitchy (but more responsive).
Old Aug 31, 2007 | 08:16 AM
tawheed's Avatar
My AP1 steers extremely precisely - comparing it to my old car - ITR
Old Aug 31, 2007 | 08:38 AM
User 122618's Avatar
i would read around a bit,
yes the ap1 is more twitchy and responsive... more raw.. many differences not only between ap1 and ap2, but even MY00/MY01, and MY02/MY03...
Old Aug 31, 2007 | 08:52 AM
Johnny Sack's Avatar
i have both cars currently, 05 TSX and 02 s2k, and my s2k is a lot more precise than my tsx.
Old Aug 31, 2007 | 09:09 AM
boofer's Avatar
oh, i'm not saying the S2000 is less precise than the TSX....i'm just talking about the steering ratio....i remember seeing the TSX's being like 14.3:1 and the S2000's being like 14.7:1, with the CR falling in at like 13.8:1.
Old Aug 31, 2007 | 09:58 AM
__redruM's Avatar
Steering ratios vary based on things like tire size and wheel base and certainly FWD vs RWD. For example the AP1 and AP2 have different numbers, but the same ratio feel, and the only difference is the tires.
Some do feel a difference between ap1 and ap2, but this has more to do with the ap1's balance than steering ratio.
Old Aug 31, 2007 | 10:38 AM
deathsled's Avatar
nothing a little jab of the right foot won't fix
Old Aug 31, 2007 | 11:15 AM
JstnRyan's Avatar
Originally Posted by boofer,Aug 31 2007, 10:09 AM
i'm just talking about the steering ratio.... [cut] with the CR falling in at like 13.8:1.
That almost sounded too good to be true. Confirmed here: http://corporate.honda.com/press/article.aspx?id=4094
Looks like I'll be doing a CR rack swap in the future.
Old Aug 31, 2007 | 11:55 AM
boofer's Avatar
so no one knows why the steering ratio is so high? you'd think Honda would want it to have super responsive, quick steering. instead, i find that it's pretty gradual from 10 to 2 o'clock turns. not sluggish, not indirect, just a little more gradual than i would like or expect.
Old Aug 31, 2007 | 12:18 PM
MULDER's Avatar
Thats the most retarded thing I have read today....
You already own a 2000 model per your info... they are using the Ap1s rack.
Originally Posted by Temple of Vtec
The 2008 model year marks the return of the AP1 S2000's original steering ratio of 13.8:1, but only in the CR model - the base '08 S2000 continues on with the AP2's slower 14.9:1 steering ratio.
Do it if you want to .... its your car. I just see the point.....
