Stock Allignment ok?
Old Jan 5, 2006 | 04:26 PM
S2K KiDD's Avatar
Thumbs up Stock Allignment ok?
I jus got my suspension in today Tein Flex.... And I was probally going to lower the car may 1.5 -2 inches will stock allignment be ok for the tires dont get camber wear???...... right now im running stock tires n wheels AP1
Old Jan 5, 2006 | 06:10 PM
GPW03's Avatar
You won't be able to get a stock spec aligment, but you could ask them to get it as close as possible for you. That's what I did, and im dropped about 1.5" all around on Buddy Club coilovers. You will definately have neg camber = camber wear on your tires being that low.
Old Jan 5, 2006 | 06:29 PM
Kyras's Avatar
I know nothing about lowering an S2000, but I do know that stock alignments suck. I have two S2000s and both needed an alignment after purchase. The '01 was eating rear tires in 5,000 miles before I got it aligned and the '05 just wasn't handling as much fun as my '01, until I got it aligned.
Old Jan 5, 2006 | 06:38 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Even with stock alingment,you will get SOME camber wear.!!!
Old Jan 5, 2006 | 06:59 PM
wanabe's Avatar
my car rubbed on all 4 when i dropped it...
i waited for a week and then had it aligned for more aggressive handling.
it drives like new, but handles even better-
and no rubbing
Old Jan 6, 2006 | 06:53 AM
gomarlins3's Avatar
Get the new alignment after the drop.
Old Jan 6, 2006 | 07:33 AM
NFRs2000NYC's Avatar
Congradulations, you have destroyed what Honda spent millions on. It eats tires because of negative camber. If you did a better alignment (UK spec) your tires would go even faster. You put on positive camber, which saves your tires, but kills handling.
Old Jan 7, 2006 | 10:18 AM
S2K KiDD's Avatar
and no rubbing
Hey wanabe what are your allignment specs sounds like your allignment is what i need...... im goin to wait for a week or so let them settle out little more then get an allignment
Old Jan 7, 2006 | 10:42 AM
PrimoGen's Avatar
1.5 is a lot of drop I would not go much more than that. Everybody else has said pretty much what I would have. I have the canadian spec alignment numbers (more toe and other slight differences) if you want them PM me
Old Jan 7, 2006 | 06:42 PM
S2K KiDD's Avatar
Why is there different allingment spec for different countrys???
