Stock Fog Lights?
Old May 4, 2004 | 08:51 PM
SolReborn's Avatar
Default Stock Fog Lights?
Are there any fogs that fit in the stock MY00-02 bumper holes?
Old May 4, 2004 | 09:24 PM
I dream of S's Avatar
yes, Honda Odyssey fog lights will fit. They don't bolt right in, but they fit. Here is how Rick did his. http://forums.s2ki.com/forums/showthread.p...amp%2520install
Those are from a 00-01 Odyssey, airgate used the style from the 02+. Hope that helps.
Old May 5, 2004 | 07:50 AM
SolReborn's Avatar
Thanks for the help
Old May 5, 2004 | 10:26 AM
mbilderback's Avatar
Just a few hints I've picked up along the way. A good way to cut the plastic out is with a wire shorted with a battery. The wire will get very hot and cut right through plastic without the fear of scratching the bumper. However, be careful not to melt anything and damage is possible this way as well. Also, you should use a DC device that can vary the amount of power going through the wire so you can lower and raise the temperature as needed. This will make a clean and smooth hole.
Also, if you want to switch the fogs with the lights so you can basically leave the switch in the on position and have the fogs only come on when you turn on the lights, you can add another relay and splice off of a running light line for your second on input.
ravi1987
Dec 23, 2009 10:59 AM
KingzS
Jun 24, 2008 09:42 AM
Givener
Jun 9, 2005 07:37 PM
pepelepew916
Nov 4, 2004 08:56 PM
TommyM
Aug 9, 2001 11:24 AM
