Storing Wheels
Old Dec 28, 2007 | 10:17 AM
superjimbo's Avatar
Default Storing Wheels
I'm about to get a new set of wheels for my car and I'm planning on keeping my stock wheels in case I need them in the future. How do most people store wheels? I live in an apartment and don't have a ton of room. There is a bit of room in the garage in front of my car where I'll probably end up stacking them on top of each other. Any advice? Should I cover them? If so, what do most people use? Just wanted to get some ideas.
Old Dec 28, 2007 | 10:31 AM
importi2acer's Avatar
i just stack them on top of each other, if you have cardboards place them between each wheel.
Old Dec 28, 2007 | 11:06 AM
CBR2200's Avatar
Put something on the ground under the bottom tire so it doesn't stain the concrete.
Old Dec 28, 2007 | 11:28 AM
freq's Avatar
Big Contractor garbage bags.
Will there be tires left on these wheels?
Old Dec 28, 2007 | 11:46 AM
superjimbo's Avatar
Great advice so far. Looks like some cardboard and a few industrial size garbage bags are the way to go
and yes, I will be storing these with the tires still on.
Old Dec 28, 2007 | 12:05 PM
TW00Si's Avatar
I've seen people stack them by twos and put a solid wooden board on top and cover it with bed sheets and use them as tables. Then again, this was seen at a friend's place that had four sets of wheels.
Old Dec 28, 2007 | 12:45 PM
CosmosMpower's Avatar
Use the 3 mil contractor trash bags, make them as airtight as possible and out of direct sunlight. Also preferrably in a temperture controlled room. Repetitive hot/cold heat cycles can shorten the usable life.
Old Dec 28, 2007 | 02:41 PM
freq's Avatar
Store them (tires moreso than wheels) away from electric motors.
Old Dec 28, 2007 | 07:38 PM
AlX Boi's Avatar
Stack it up like those tire shops and lean the top one up to display it as a nice design to the place in a corner of your apartment.
Old Dec 29, 2007 | 08:33 AM
Mocky's Avatar
tirerack has wheel covers....i'm using those... and then stack them somewhere with a cardboard spacer between the wheels
