Superleggeras
Old Jul 1, 2005 | 04:26 PM
cRAVeN MoOrEhEaD's Avatar
Default Superleggeras
17x8 O.Z. Superleggeras one piece monoblocks that weigh 16 lbs. each. The bolt pattern is 5x114.3 and the offset is +48. will these fit a S2k ? I need to know quick
Old Jul 1, 2005 | 06:46 PM
CBeyond's Avatar
Yes, I am running OZ Superleggera 17s. The only problem I encountered was with the rear centering rings, which were a little too small. I removed some metal from the inside of the rings, and they work fine. I have not verified if this is a common problem, or if it only affected me.
On an AP1, the tires come right out flush with the body, so if your car is lowered, you may encounter some rubbing under certain conditions. My suspension is stock, and I have ZERO problems.
Old Jul 1, 2005 | 10:31 PM
NFRs2000NYC's Avatar
Make sure the rings are correct, or else the rims wont sit right.
tonydang25
Mar 23, 2009 03:46 PM
Sol4God
Nov 17, 2008 05:24 PM
toohektic18
Feb 25, 2008 11:55 AM
pinoyk20
Sep 4, 2007 11:01 PM
Silver_S2000
Dec 6, 2005 07:43 AM
