suspension creak
Old Jul 29, 2005 | 01:39 PM
dyhppy's Avatar
Default suspension creak
everytime i go over a bump there is a rubbery creak/squeak that can be heard. honda checked it out, lubricated bushings and retorqued suspension components and the sound is still there. can someone suggest what else it might be? suspension is bone stock.
thank you
Old Jul 29, 2005 | 03:58 PM
dyhppy's Avatar
please someone help
Old Jul 29, 2005 | 04:58 PM
Dantheman's Avatar
I don't know if this is a possibility but the creak/squeek noise MIGHT be coming from the soft top (I'm assuming you have a soft top). My soft top squeeks at the driver's side latch whenever I go over a bump, especially when I go over the little reflectors in between the lines for the lanes. I still haven't figured out how to get rid of it though. Hopefully this helps.
Old Jul 29, 2005 | 05:16 PM
landfighter's Avatar
I also had a mystery squeak that the dealer could not find, that was only heard at low speeds over small bumps. After also lubricating bushings, re-torqued suspension, etc.. I found it to be the rubber between the right front spring seat/lower spring coil. I sprayed it with white lithium spray grease, 6 months....no squeaks hope it helps.
Old Jul 29, 2005 | 11:59 PM
dyhppy's Avatar
thank you, ill try it.
it's definitely not from the soft top.
Croc
Jun 26, 2015 06:28 PM
jdblood202
Oct 24, 2013 07:42 AM
boyguan
Oct 12, 2005 01:43 AM
axis_of_evil
Mar 17, 2005 10:54 AM
spdlmtna
Jul 30, 2004 12:23 PM
