Suspension question MY 2000 vs MY 2002
Is it possible to change MY 2000 suspension to MY 2002 ???????
Is there a point to do so ????
The difference in handling is that much so, if possible, it is better to make the switch ?????
spring rate is different(softer) from what I hear. I have an '02.
stock shock is that same.
the sway bars are smaller on an '02.
that is it.
www.ground-control.com, I am seriously thinking about going to them for coil-overs, cause you get to select your own spring rate that is applicable to what you want to accomplish and you can pretty much combo what ever shock you want. A very univeral shock set up. 399.00 for springs and adjutable perch that works with the stock shock.
that is it.
