suspension(shocks + F. sway) for S2000?
Old May 30, 2005 | 03:29 PM
jack1122's Avatar
Default suspension(shocks + F. sway) for S2000?
planning to do some suspension work on my 02' s2k.
-shocks.(2 way adjust or less)
-F. sway bar..
any suggestion about which brand/model to get?
the reason of those mod is to complete w/ SCCA stock class for autoX
thx.
Old May 30, 2005 | 05:08 PM
Fongu's Avatar
Here is the Autocross FAQ. Has all the formula for SCCA stock class S2000 setup. Enjoy.
http://forums.s2ki.com/forums/index.php?showtopic=172595
Old May 30, 2005 | 07:05 PM
ImportSport's Avatar
This is a long discussion. How much do you want to spend?
Koni yellows are going to be your most affordable shock option. But youre not going to see a huge time difference on shocks. Tires and lower swaybar are your big points, plus brake pads.
There are really only 3 sway bars that I would consider. Comptech, Gendron and Saner. The Comptech and Gendron are easiest to get. The comptech is a bit more but once your over that $600 mark +/- $50 doesnt make much of a difference.
If you havent taken the evolution driving school I would suggest doing this before you do any major mods to the car. I would probably do the swaybar first, race a while, take a school, race more, buy R compounds your second season, then shocks at some point after that.
Old May 31, 2005 | 09:50 PM
jack1122's Avatar
so the koni yellow is not as good as the stock shocks??
i heard about injecting thicker oil into the shocks to add stiffness, is that true? any pro or cons?
Old Jun 2, 2005 | 02:17 PM
jack1122's Avatar
any1??
Old Jun 2, 2005 | 08:40 PM
jonam's Avatar
I am curious to know this as well...
Also not many people seem not to consider Double adjustable Konis, which cost around $350-400 per corner..
simpletantra
Oct 14, 2006 11:56 PM
MaxGeek
15
Aug 2, 2005 08:46 AM
egg45us
Feb 24, 2005 06:37 PM
jim cannatti
Apr 4, 2002 08:56 PM
