suspension squeek
hey guys i was wondering if anyone had this problem. but anyway at a stop when i turn my wheel side to side the right side front would make a squeeking sound. i was just wondering if anyone know what it might be
Originally Posted by s2kpr01,Jan 8 2006, 06:55 PM
i also have the same problem... but mine if i go over a bump it squeeks and i f i turn to the left the same sound... could it be a bushing or something like that ?
I had this exact squeak in my car. It turned out to be the passenger side front brake line that rubbed against the passage from the wheel well to the motor compartment.
And it was very easy to eliminate. Just grease the brake line in that area.
Passenger side, front wheel well:
sorry for the crappy pic.
Squeeks are as unique as their owners. Every one will have a different source, but I'll tell you the one I just tracked down......
My hood prop was rubbing against the Comptech Intake the other day. Very evident at low speeds, idling at a stop, or bumps. I have now removed the hood prop and ordered the NRG hood dampers.
Again, it could be a dozen things causing it. You'll probably have to dive in and start checking/wiggling everything you can.
Fun, fun, fun.
Fun, fun, fun.
I had a crazy sqeeking problem coming from my rear passenger side everytime i went over a bump or a tiny dip at low speeds. found out that one of my upper arm bolts was a little loose. that could be one of the problems, but as hockey said, it could be other things as well
