sway bars
Old Apr 22, 2007 | 02:31 PM
IDGHW's Avatar
Banned
Default sway bars
Sway Bars for the S2000 by ASM. 4 versions available, price is per sway bar, please specify quantity and stiffness when ordering. Front-soft Front-hard Rear-soft Rear-hard
can someone help...... hard or soft sway bars....whats better for what?
Old Apr 22, 2007 | 03:23 PM
Project22a's Avatar
Stiffening the front or softening the rear induces understeer and/or reduces oversteer.
Stiffening the rear or softening the front induces oversteer and/or reduces understeer.
Most people here like to keep their rears more planted so they upgrade their fronts to a stiffer one. Some people here disconnect their rear completely.
Old Apr 22, 2007 | 03:41 PM
623baller's Avatar
so i guess stiffening the front, you have less of a chance of the rear coming out?
what about x braces?
do they work better than sway bars?
Old Apr 22, 2007 | 03:49 PM
RED MX5's Avatar
An stiffer anti-roll bar ("sway bar") makes the end of the car where it is installed handle more of the total weight transfer during cornering. Bigger front bar = less oversteer.
A chassis brace is a chassis modification and the effects are minimal compared to anti-roll bars. Put the money in a good adjustable front bar instead.
Are you running R compound tires?
Old Apr 22, 2007 | 11:45 PM
623baller's Avatar
no, i'm not running r compound tires, and im not planning on autoxing the car either, i just want the peace of mind that my rear end will not come out on me and cause a spin out during a little spirited driving, also on wet conditions.
is sway bar still the way to go?
also, does sway bars add complications to oil changes?
Old Apr 23, 2007 | 03:17 AM
ricosuave's Avatar
no.
Old Apr 23, 2007 | 08:19 AM
Project22a's Avatar
You could also try increasing your stagger with a 215/255 tire setup. But a stiffer front sway bar is the way to go imo. I wouldn't disconnect the rear bar unless you're into tracking your car.
A sway bar won't get in the way of your oil changes. You're not *adding* a sway bar; our cars are already equipped with them. What you're doing is replacing it with a bigger/stiffer one.
Old Apr 23, 2007 | 01:48 PM
RED MX5's Avatar
[QUOTE=623baller,Apr 23 2007, 02:45 AM]no, i'm not running r compound tires, and im not planning on autoxing the car either,
Old Apr 23, 2007 | 02:08 PM
623baller's Avatar
i defintely agree with you MX-5,i thought about lessons and all
but i just want that assurance if sway bar is the way to go in terms of wet condition and during some fun cornerings
again im not looking to race, and i don't really want to mod the car as well, i just want to be SAFE of what the road throw at me be it the weather or the corners.
in that case, i guess im better off getting a wider rear tires to keep the back in check?
Old Apr 23, 2007 | 02:51 PM
afwfjustin's Avatar
Get some 275s and roll those fenders
