Taking off air box?
Old May 29, 2001 | 02:54 PM
VTEC Racer's Avatar
Does anybody here know if taking off the airbox gives the car more power? I'm assuming since the air filter is more open to the engine bay, it can suck in more heat which would cause a performance loss. But if it were night and the weather was cool, and the intake could get cold air, wouldnt it gain performance? Either way, day or night, has it been proven on a Dyno whether taking the airbox off is good or not? Thanks in advance!
Old May 29, 2001 | 02:56 PM
2x6spds's Avatar
[QUOTE]Originally posted by VTEC Racer
[B]Does anybody here know if taking off the airbox gives the car more power? I'm assuming since the air filter is more open to the engine bay, it can suck in more heat which would cause a performance loss. But if it were night and the weather was cool, and the intake could get cold air, wouldnt it gain performance? Either way, day or night, has it been proven on a Dyno whether taking the airbox off is good or not? Thanks in advance!
Old May 29, 2001 | 02:59 PM
Phantom's Avatar
If there are gains...it won't be significant...but it does sound good.
Old May 29, 2001 | 03:00 PM
Nick Graves's Avatar
I assume that on the dyno, the car was static
The trumpet on the airbox in the high pressure zone in front of the radiator, plus the compartmentalisation of the air box suggests that Honda may be employing a ram-air technique at higher speeds.
Old May 29, 2001 | 03:23 PM
Jay Li's Avatar
I ran my car with the airbox off in 40 degree weather, and I still could feel a noticeable loss in performance. It does sound nice, but I leave it on.
Old May 29, 2001 | 03:26 PM
Phantom's Avatar
The only way to get performance out of the open box top is if you cut the hood for some kind of scoop.
Old May 29, 2001 | 03:32 PM
lvs2k's Avatar
Been there, done that, do a search.
Old May 29, 2001 | 05:33 PM
nvmys2k's Avatar
How could there be a gain in performance when your air filter is sucking hot air with the airbox top off? You would lose less power in cold weather though. Bottom line there is always hot air under the hood when your car is moving. How much hot air under the hood depends on outside temperature.
Old May 29, 2001 | 06:15 PM
Knowledge's Avatar
Just buy one of these. They're only $1500!
Old May 30, 2001 | 04:36 AM
Allan Haggai's Avatar
My dyno run with the air box cover off showed a small peak HP gain, but a 10 - 12 hp loss from 3,000 - 6,000 rpm.
