Tech2 Front Mount
Old Jul 18, 2004 | 12:42 PM
buckeye1's Avatar
Default Tech2 Front Mount
Im trying to get some input on Ait Intake Temps compared to the stock radiator for the after cooler. My intake air temps are around 130 degrees. Will the Tech2 radiator drop the temp?
Old Jul 18, 2004 | 02:21 PM
AusS2000's Avatar
I doubt the Tech 2 will make your charge cooler, it just raises the level at which you start getting heat soak. So if you drive your car hard and the coolant can't keep up (your AITs start to rise) then a higher capacity radiator is required.
Old Jul 18, 2004 | 02:27 PM
buckeye1's Avatar
wouldnt you consider 130 degree IATs heat soak?
Old Jul 18, 2004 | 03:36 PM
AusS2000's Avatar
No, heat soak is when the hardware and coolant absorbs more heat than is dissipated.
A result of heat soak might be a high AIT, but it depends whether or not the AIT climbs from a lower temp to 130 over a period of time, or whether it is at 130 from the beginning. If it's the former, then a bigger radiator is required. If it's the latter then it's simply the limits of the system (heat from compression minus cooling from heat exchanger) and changing the radiator won't do diddly.
Old Jul 29, 2004 | 02:49 PM
honda9krpm's Avatar
buckeye1, is this intak temp with your current boost? What was the air temp at the time?
with the boost that you are running, I believe the upgrade will be highly beneficial.
Ek_Jak
Nov 29, 2015 11:14 AM
Ek_Jak
Apr 17, 2012 06:25 PM
mpower22
Jul 25, 2007 11:03 AM
