A technical question.
I've noticed some posts about some front spoilers with "canards" incorporated therein, which add downforce to the front at speed. Also, there are of course rear spoilers that add downforce to the rear at speed.
Here's my question. Why does the car need this downforce at speed? Somebody told me that, at speed, the air pressure under the car is greater than that in the ambient atmosphere, thereby "lifting" the car. Is this true? If so, I'd like to know. If not, I'm curious about why our cars need more downforce at speed.
Thanks,
Richard
Thanks,
Richard
technically, a car is much like an airplane wing. Flat on the bottom, rounded on the top. It takes the same amount of air longer to travel over the top of the car than it does under it. According to the equalization of gas principle, the air that goes over the car must travel a longer distance in the same amount of time (thus making it go faster). This creates a low pressure area over the car, and a high pressure under the car. Canards and rear diffusers are meant to "diffuse" the low pressure area and to produce downforce, which cancels the low pressure.
Google "Bernoulli's Principle." (I think that is how you spell it). It is the same principle that keeps a plane in the air.
John
John
John:
Good explanation!
Now a second question. I understand that the airflow over the curved surface on the top side of the car produces "lift" as in an airplane wing. But does also the air pressure beneath the car increase over ambient air pressure at speed?
Thanks,
Richard
Good explanation!
Thanks,
Richard
It you have a front diffuser, no. it diverts air from UNDER the car, thus creating sort of a vacuum effect. This is why the Ford GT has a COMPLETELY smooth under carriage, with front AND rear diffusers, the engineers wanted to get the air to go around the car, instead of under it. The more air under the car, the greater the pressure. Ford wanted to keep air from going under the car. This is why the Saleen S7 can, technically, drive upside down at speeds greater than 150.....it creates more downforce that the car weighs.
John
John
That sounds about right.....there was a HUGE controversy in INDY in the 50's because (I think it was) Lotus who entered a car that had 2 engines....1 for driving the car, and 1 to power a fan under the car that "sucked" the car to the ground. Won by a TON!
John
John
Of course, if you have a big gap in our hood edges or a poor fitting hood, some of the air (and the pressure) will go there.
Chaparral
Originally Posted by N8dawgSMU
indy cars have an inverted bubble underneath their body, creating a vacuum. i once read at 60 mph an indy car could technically drive upside down.
Not trying to pick you guys apart, but I do this for a living
Bernoulli is the man.
Pressure forces triple with speed. there is three times as much drag/lift/downforce on a car at 100 mph compared to 50 mph.
Now, this is force, not energy & power. The power required to overcome the force and keep a vehicle moving at speed is proportional to the cube of the velocity (~v^3). This is why those NASCAR things run >600HP but only go 200 or so. HPH
