Tein S-Tech vs. Eibach Pro Kit...
Old Sep 4, 2006 | 11:33 AM
Jo2's Avatar
Jo2
Default Tein S-Tech vs. Eibach Pro Kit...
I've narrowed it down to these two. Seems like they drop is about the same. After searching, it's sort of inconclusive, some say tein drops lower, some say eibach. Regardless, is there any reason to go with one over the other assuming price isn't an issue? Is one a better quality then the other? Seems stupid but i'm leaning towards tein because they are a japan product for a japan car....
Old Sep 4, 2006 | 04:55 PM
METATRON's Avatar
Well Eibach has the million mile warranty. While Tein has a one year warranty on their products. I went with Eibach because they have been around a lot longer. And their suspensions are used much more in racing.
Old Sep 4, 2006 | 05:43 PM
iDomN8U's Avatar
Eibach Pro lower's 1 inch Front and Rear (.PDF doesn't list Spring Rate)
Tein S-Tech: Lowers 26mm front, 25 mm rear (almost 1 inch) and has a spring rate of Front 5.3/296 - Rear 6.5/363
http://www.tein.com/ti/a58.html
Pretty sure both are Linear springs.
I'm in the same boat as you, I hear progressive springs are your best bet (KGMM I believe are), but i'm leaning towards Tein since I like the spring rate (good for Ap1)
Old Sep 4, 2006 | 05:47 PM
S2kracka's Avatar
Eibach Pro-Kit springs are progressive while the Tein S-Tech are linear. I'd personally go with the Eibach springs, they are definitely going to be better in quality than the Tein springs, better comfort, and more than likely better handling. I hope you are ordering a set of aftermarket shocks to go along with these lowering springs.
Old Sep 4, 2006 | 06:07 PM
iDomN8U's Avatar
But whats it spring rate? I need to compare numbers and cant find sqwat on the Eibach
Old Sep 4, 2006 | 06:10 PM
JDM S2000's Avatar
Banned
There is a thread somewhere on here with spring rates, but i cant find it.
I have the eibachs and so far so good on stock shocks
Old Sep 5, 2006 | 05:57 AM
iDomN8U's Avatar
Found the Thread, not sure if this is accurate today.
https://www.s2ki.com/forums/index.php?showt...0&#entry5818832
Old Sep 6, 2006 | 07:39 PM
Jo2's Avatar
Jo2
Ok well I bit the bullet and went with Eibach. Got them for $230 shipped off of ebay. Hopefully i'll receive them and have them installed by next week at the latest.
Old Sep 6, 2006 | 08:30 PM
S2K626's Avatar
Where's the cheapest place to get the Eibach Pro-kit? BTW I live in CA
Old Sep 7, 2006 | 03:11 AM
METATRON's Avatar
$230.00!
