test pipe
Old Sep 21, 2005 | 08:23 PM
JspecVtec's Avatar
Default test pipe
is it worth it? gains noticeable? thinkin about test pipe with stock exhaust
Old Sep 21, 2005 | 08:33 PM
Luke530's Avatar
Not sure about stock exhaust... but you could see maybe 8-10 wheel horsepower with test pipe & aftermarket exhaust. Change your exhause first.
Old Sep 21, 2005 | 09:12 PM
Silver9k's Avatar
I have just test pipe on stock exhaust...not a huge difference. But its not bad either. If your planning on upgrading the exhaust in the future then its not a bad idea to get one now. Besides it also deepens the exhaust note slightly with it
Old Sep 21, 2005 | 09:14 PM
Tony Yeung's Avatar
Some test pipes are straight pipes, some have built in resonators. It is good if your mentioning your experience to include what brand you have for reference.
Old Sep 22, 2005 | 02:26 AM
RACER's Avatar
Give a hoot and don't pollute.
Old Sep 22, 2005 | 05:41 AM
Mr. Francesco's Avatar
i had a very noticable gain, but i also have a header and exhaust
Old Sep 22, 2005 | 11:07 AM
jyeung528's Avatar
what does a test pipe do?
and why does an aftermarket exhaust help, when an aftermarket exhaust does not make a difference without a test pipe?
Old Sep 22, 2005 | 12:31 PM
InspireS2K's Avatar
Aftermarket exhausts vary in performance gains. Depending on what aftermarket exhaust you go with, you would be looking at 0-12whp gains. Dyno proven T1R 63mm single exhaust which includes a test pipe showed 12.1 whp gains.
A test pipe replaces the catalytic convertor. To maxmize gain people choose to replace they catalytic convertor with a test pipe (aka. straight pipe) to eliminate the exhaust/air flow restriction.
I hope this helps.
Cheers,
InspireS2K
Old Sep 22, 2005 | 04:06 PM
mikehn's Avatar
Cheers,
Old Sep 22, 2005 | 04:19 PM
jyeung528's Avatar
test pipe sounds illegal?
is it illegal?
would it pass smog tests?
I assume you guys switch back to catalytic converter for smog checks?
