Is thie Normal..or what?
Old Nov 15, 2010 | 07:01 PM
  #21
SgtB's Avatar
I've seen a big money 36 roadster fall out of the rack. Not pretty. It had a custom matched trailer and everything.
Old Nov 15, 2010 | 07:23 PM
  #22
Nick.'s Avatar
i drive cars on the lift almost on a daily basis, part of the job i guess. if the car is well supported i don't think it's really an issue.
did you find the noise?
Old Nov 15, 2010 | 07:28 PM
  #23
RedY2KS2k's Avatar
Originally Posted by Matt15,Nov 15 2010, 08:33 PM
really think about it for a second. if you were under your car and i came and started shaking it how would you feel? ...
Wouldn't bother me one bit; I wouldn't be under there unless I'd already tried that myself and failed to shake the car. One jack stand under each of the four jack points makes the car so stable I can't shake it. And believe me, I give it the old college try before crawling under it.
With the car running at idle in first gear, I'd be more worried about tangling my hair or clothing on some spinning part (driveshaft or half-shaft) than about the car falling on me.
Your jack stands and garage floor may be different. The bottom line is we're each responsible for our own safety; if you aren't comfortable, don't do it.
Old Nov 15, 2010 | 07:44 PM
  #24
Nick.'s Avatar
/thread
Old Nov 15, 2010 | 08:25 PM
  #25
s2000maniac's Avatar
you are all getting this wrong...... i was NOT driving the car while it was on the jack stands....the car was in nuetral the whole time, i just turned it on and tried to listen to see if i could hear that clicking sound. I WAS NOT under the car, I was by the driver side wheel.
Old Nov 15, 2010 | 10:39 PM
  #26
dirtykoala's Avatar
so you didnt drive anywhere while the car was in the air on jack stands?
Old Nov 16, 2010 | 03:09 AM
  #27
KENNETH HAFT's Avatar
not sure why wheel would be turning at different rates
kenneth haft
Old Nov 16, 2010 | 03:34 AM
  #28
ahrmike's Avatar
if clutch was out and the rear wheels were turning, you might have a problem. Unless its the transmission fluid transferring motion, that should NOT be happening.
The torsen differential is set up so that in the air, it pretty much acts as an open differential.
Old Nov 16, 2010 | 04:24 AM
  #29
takeshi's Avatar
Explained earlier in the thread.
Old Nov 16, 2010 | 04:56 AM
  #30
TougeS2k's Avatar
Im pretty sure i can rep an s2000 (spare tire removed) 6 times.
