Tire Cradles
Old Jan 4, 2005 | 06:29 PM
LUV2REV's Avatar
Default Tire Cradles
Curious to know if any S2000 owners use Tire Cradles for winter storage ? I went to look at a 1994 Viper today and noticed the Tire Cradles. I have never had issues with flatspotting during the winter storage of any of my vehicles. I would probably buy a set (for peace of mind) if not for the $450 CDN price for 4 pieces of foam !! I went to their website and they indicate the outlandish price is due to an expensive polymer used in their manufacturing process. Do I need these ?
Old Jan 4, 2005 | 06:40 PM
Chazmo's Avatar
Flat spotting is not much of an issue anymore these days with current tire technology, LUV... However, rubber rot surely can be, especially if you park on concrete (or perhaps loose dirt).
I seriously doubt you need anything fancy. A sheet of plastic or even corrugated cardboard is probably fine to avoid any issues.
Besides, I don't know about you, but I only get at most a driving season (spring - fall) and a half out of my rears and maybe two seasons out of my fronts.
hapa's Avatar
just stack them up flat on the ground...put garbadge bags on them if you want to protect from ozone. In a cool dry place off of the ground would be best. if you don't have that, then just put some cardboard under them.
If you want to spend the big bling be my guess, but I wouldn't worry.
by the way I work for a tire manufacturer so don't be fooled by these bogus racks. What do you need a rack to be made of polymer for? Is it going to be launched into space?
Old Jan 4, 2005 | 07:07 PM
Silverstreak HX's Avatar
Cheapest solution- Go to a carpet store and get some sample carpet squares for 1 dollar a piece!
Old Jan 4, 2005 | 07:12 PM
LUV2REV's Avatar
Sorry, I think you misinterpreted what the Tire Cradles are. They are a branded product (www.tirecradles.com) that you actually drive your vehicle onto. They are not for storing wheels that have been removed from a vehicle.
Old Jan 4, 2005 | 07:40 PM
Nishant's Avatar
could you explain rubber rotting on concrete?
my S is being stored in my garage. The floor is concrete. I painted with special garage paint for tires. Would my tires rot?
Old Jan 4, 2005 | 07:49 PM
Chazmo's Avatar
Concrete is quite absorbent, SBS. I'm not absolutely certain about this, but I think the issue is that the surfaces that are in contact with the concrete will be subject to cracking (we're talking extended time here, not just a month or two) because they dry out.\
I think your garage paint will not be absorbent, so you're probably fine. Even so, the suggestions here were all good -- carpet, plastic -- these should work fine to isolate the tire from the garage/ground surface.
sang
Oct 6, 2011 07:10 PM
andrewchengs
Feb 7, 2005 08:58 AM
